5 years agoNot applicable
Power BI Dataflow does not refresh dataset after changing F Code
Hi
I have a power bi dataflow, I just change the Select criteria on the f Code, Dataflow does render the change but it does not push the data to the data set
If you use import mode then you need to refresh the dataset after you refreshed the dataflow. In Direct Query mode you onnly need to refresh the dataflow.
1 Reply
- lbendlin
