JHob
Advocate I
5 years agoPower BI Dataflow Connection issue
Hi Is anyone experiencing issues with Power BI Dataflows. I am getting the following error when I try and edit any of the queries. This is happening in Power BI Dataflows that I hav...
- 5 years ago
Thanks Nicky
I found out that I needed to reselect the gateway under Options and Project Options in order for it to connect. However evertime I save the dataflow and then reopen it I have the same situation and need to reselect Options and Project Options
- Anonymous5 years ago
Hi JHob ,
Troubleshooting dataflow issues - connection to the data source | Microsoft Docs
Did you change the type of data source connected? The data source used in the Power Query editor in Power BI Desktop here is different from the one in the configure connection. If so, it is best to make sure that the configuration and credentials used in the front and back ends are the same.
Yuna
hvanstalle
5 years agoFrequent Visitor
I have exactly the same issue.
PaulKn
Advocate II
5 years agoSame issue for me too. Very frustrating.
