Power BI Dataflow - Power BI Dataset
Hi there
I am currently facing issues with Dataflows in combination with Datasets.
In my Dataflow I had, a while ago, an property with 3 different records. I changed the queries, rebuild the logic and updated the Dataflow, so that now this property has only 1 record (which is fine). When I connect a PBIX Dataset to this flow and query the data, I keep getting the property with the 3 different records.
Before you ask:
- I refreshed the Dataflow, I refreshed the Dataset, still 3 records
- Then, I added a custom column, refreshed the Dataset: The custom column appears, but the 3 records are still there
- I created a new Dataset, connected to the Dataflow, still 3 records
- I created the Dataflow from scratch, then it worked - only 1 record
(but now comes the funny part: after my 2 weeks holiday -
the new flow now shows 3 records again in the Dataset (as well as in new PBIX files connecting to the Dataflow)
What is going on there?
We are seeing a similar issue in another Dataflow as well.
Thanks for your help
Christian
