ucmaoTWG
1 year agoPaginated Report connection problems / Analysis Services engine
Hello, I have a Paginated Report that had been working for 1+ years without an issue until now. 1) It is connected to PowerBI as a datasource. 2) The connection string from powerbi to our azure...
- 1 year ago
The problem has been resolved after 6 months tracing and testing- we had to enable private link in our powerbi tenant in order for users to connect to semantic models in the analysis system.
V-yubandi-msft
1 year agoHi ucmaoTWG ,
Just checking in has your issue been resolved, or are you still facing any challenges. If the solution provided helped, please consider marking it as an accepted solution so it can benefit others in the community as well.
Thanks.
