Anonymous's avatar
2 years ago
Need Help in Using Matrix Table in Power BI
I created a matrix table using debtor code as data on the row. but upon adding data on the values like terms, currency, invoice numbers and other things  the matrix provided me first, sum, count, etc. which i don't really needed (see second screenshot).
I just want to get the exact data from the first screenshot when add them on the values of the matrix table.
is this possible?
  • mohitkumawat's avatar
    mohitkumawat
    Icon for Impactful Individual rankImpactful Individual
    Hi Anonymous ,
    Instead of using matrix Visual use Table Visual.
    If this post helps, then please consider Accept it as the solution, Appreciate your Kudos!!
    i had a separate power bi using table but i prefer to use matrix. is it not possible to create measures in matrix to address my requirements?
