Flowy's avatar
Flowy
4 years ago
Memory problems - Power BI Capacity
I've a workspace assigned to a Premium capacity (A1) but refresh datasets is not working (before assigne a capacity it was working).   Erro de fonte de dados: Resource Governing: This operation was...
  • v-yadongf-msft's avatar
    4 years ago
    Hi Flowy ,
    Please note the A1 SKU limit on dataset memory:
    Capacity and SKUs in Power BI embedded analytics - Power BI | Microsoft Docs
    Refresh is a background operation that can occur when two conditions are met:
    • There is sufficient memory
    • The number of supported concurrent refreshes for the Premium capacity is not exceeded
    When the conditions are not met, the refresh is queued until the conditions are favorable.
    For a full refresh, recall that at least double the current dataset memory size is required. If sufficient memory is not available, then the refresh cannot commence until model eviction frees up memory - this means delays until one or more datasets becomes inactive and can be evicted.
    For more information, please refer to: Optimize Microsoft Power BI Premium capacities - Power BI | Microsoft Docs
    Please check if there is any remaining memory in the workspaces.
    Best regards,
    Yadong Fang
