Memory problems - Power BI Capacity
- 4 years ago
Hi Flowy ,
Please note the A1 SKU limit on dataset memory:
Capacity and SKUs in Power BI embedded analytics - Power BI | Microsoft Docs
Refresh is a background operation that can occur when two conditions are met:
- There is sufficient memory
- The number of supported concurrent refreshes for the Premium capacity is not exceeded
When the conditions are not met, the refresh is queued until the conditions are favorable.
For a full refresh, recall that at least double the current dataset memory size is required. If sufficient memory is not available, then the refresh cannot commence until model eviction frees up memory - this means delays until one or more datasets becomes inactive and can be evicted.
For more information, please refer to: Optimize Microsoft Power BI Premium capacities - Power BI | Microsoft Docs
Please check if there is any remaining memory in the workspaces.
Best regards,
Yadong Fang
An A1 sku only allows for very small datasets - 3GB max. You generally need 2-2.5X the memory of your dataset so it can refresh. For a brief period in time your dataset is doubled in size as the old data isn't discarded until the latest refresh can be completely swapped in. That way you lose nothing during a failed refresh. That depends too on how much is swapped out via incremental refresh. The more you have in historical partitions, the less RAM it will take as those aren't swapped out during a refresh.
I am honestly not sure why it was working if it was previously Pro as that has a 1GB per dataset limit. Is it possible it was in a Premium Per User workspace - PPU? That has a 100GB dataset.
Regardless, a dataset nearly 3GB in size will not work well in an A1 capacity.
- Jannematz3 years agoFrequent Visitor
We actually have the same experience with pro having no memory limit during dataset refreshs. We are currently thinking about switching back from premium/fabric to pro, because it doesn't have a memory limit and doesn't need to be micro-managed to supply enough memory before a refresh. (upscaling before a refresh, downscaling afterwards). Its also way cheaper for us in our constellation (included in our partner subscription)..
I read that microsoft uses shared ressources for pro workspaces and therefore there is no limit on how much memory is consumed by all the datasets as long as each one is smaller than 1gb in storage size. So you can refresh as many as you want at the same time.
- edhans3 years ago
PPU might be a better alternative as it is equivalent to a P3 capacity for memory limits (100GB datasets for example) and is also shared, but you get the advantages of premium features like deployment pipelines, xmla endpoint access, etc.
