Filter a Power BI Tile using query string paramaters and IN operator.
I'm trying to filter a power Bi Tile on my PowerApps application, as it written in this article: https://learn.microsoft.com/en-us/power-bi/collaborate-share/service-url-filters
It's works well with the "eq" operator but when I tried to use the "in" operator it doesn't work.
For example adding this to the end of the TileUrl works:
&filter=Etat_Consigne_Approb/Approbateur eq ('XXXX xxxx')
But this doesn't work:
&filter=Etat_Consigne_Approb/Approbateur in ('XXXX xxxx','ZZZZ zzzz')
Thanks by advance
I can provide other info if necessary
Hi , Anonymous
According to my research, each value in the set after the in operator needs to be separated by a space, you can try something like this
&filter=Etat_Consigne_Approb/Approbateur in ('XXXX xxxx', 'ZZZZ zzzz')Here is an introduction document about the operator in the URL filter, you can see and try according to the example inside:
OData IN Operator filter function - OData | Microsoft Learn
Aniya Zhang
- v-yueyunzh-msft
Hi , Anonymous
Aniya Zhang
- ppuser3New Member
Hi, the space also doesn't work. Any other fixes? The IN operator is not working via Power Apps for a Power BI tile. I've tried everything includign the allow new API, special characters, etc.
- AlzoNew Member
Was this solved? I can use the 'in' operator for a full report but not for a tile?
