adi38612
2 years agoFrequent Visitor
Create Power BI Dataflow using a Semantic Model
Is it possible to create a Power BI Dataflow using a Power BI Semantic Model? I have a Power BI Semantic Model being shared with me by the user/creator of the dataset. Now I want to use one table in...
James_J78
1 year agoNew Member
This is late, but ou can use the Analysis Services Database connector in power query within Power bi desktop
and use the semantic models server connection string. Then you can transform the data from the other semantic model. However this method is an import mode though, but leverages native query and will only I port the data you actual query within the model.
