adi38612's avatar
adi38612
2 years ago
Create Power BI Dataflow using a Semantic Model
Is it possible to create a Power BI Dataflow using a Power BI Semantic Model? I have a Power BI Semantic Model being shared with me by the user/creator of the dataset. Now I want to use one table in...
  • aj1973's avatar
    2 years ago
    Hi adi38612
    The answer is No, You can't create a Dataflow from a Semantic model. You can use Direct Query connection to AAS(Or Power BI service)
    and then you pick your Table. But you want be able to edit the Table in power query.
