rdops
Helper III
6 years agoVisualise two different data sets in one chart
Hi all, I am totally new to PBI, have been exploring it for approx 1 month now and still have very limited knowledge. I hit a wall while trying to combine/visualise two sets of data from differen...
v-juanli-msft
6 years agoHi rdops
Is this problem sloved?
If it is sloved, could you kindly accept it as a solution to close this case?
If not, please let me know.
Maggie
- rdops6 years ago
Helper III
Hi Maggie,
It didnt work for me. Not sure if I did something wrong but even after following all these steps I still couldnt see the two sets of data separately. I ended up rebuilding the report and created a new column with a lookvalue formula to match the employees names, but for some reason, even with the employees being consistent across both systems, data from only one systems gets updated when I select the month. I guess you can close the case. I will play around with the dates/months now and if I cant find a solution I will open another thread specific to dates.
