Using Power Query SDK
- Anonymous1 year ago
Hi jaryszek,
It means that Power BI Desktop does not provide a built-in API to programmatically insert or modify Power Query (.m) code inside a ".pbix" file, but using Power BI Templates (.pbit) allows you to store queries separately from data, making it easier to manage and reuse them across reports.
To integrate .pq files into a development pipeline, you can:
* Merge .pq files into a single .m script and store it in version control (e.g., Git, Azure DevOps).
* Use a ".pbit" template containing predefined queries to create reports dynamically.
* Then use PowerShell or Power BI REST API to create ".pbux" reports dynamically from the
template.
* Once the ".pbix" file is created, you can publish it automatically using the Power BI REST API or
PowerShell.
If I misunderstand your needs or you still have problems on it, please feel free to let us know.
Hammad.
Community Support TeamIf this post helps then please mark it as a solution, so that other members find it more quickly.
Hi jaryszek,
Thanks for reaching out to the Microsoft fabric community forum.
It looks like you want to automate the import of multiple ".pq" Files into Power BI Desktop & Service. You can merge all .pq files into a single .m script automatically using powershell. As for creating parameters & dynamically changing them, you can add new parameters and update them using REST API.
I would also take a moment to thank lbendlin, for actively participating in the community forum and for the solutions you’ve been sharing in the community forum. Your contributions make a real difference.
Hammad.
Before I close the topic:
"You can merge all .pq files into a single .m script automatically using powershell."
How after merging code using powershell put it into power BI Desktop? Do you have any code examples?
Best,
Jacek
- Anonymous1 year agoNot applicable
Hi jaryszek,
Power BI Desktop does not have native APIs for direct .m code injection. But, after merging the files into a single .m script, we can use Power BI Template Files (.pbit) which store queries separately from data.
Hammad.
- jaryszek1 year ago
thank you.
If i would have template file, can i use it for building pwoer bi reports with queries sitting there?
Best Wishes,
Jacek- Anonymous1 year agoNot applicable
Hi jaryszek,
Yes, you can use a Power BI Template to build new reports while keeping the queries intact.
