jnickell
Helper V
6 years agoUsing a variable for statement in PowerQuery Beta for SSIS
I'm trying to use the PowerQuery Beta for some SSIS packages. I was curious if any one had used this, in particular the ability to set a PowerQuery equivalent to a variable. I've "gotten" it to wor...
jnickell
Helper V
2 years agoI wound up coming back to this for a new project and believe I figured out what I needed to do to translate Power Query in Power BI to a SSIS variable. Mainly documenting this for my future self.
The main thing is that any " characters need to be escaped and if you're using a variable inline, the string needs to be broken and concatenated with the variable using a + .
Hope this is helpful to others.
Original PQ sample
Source = Folder.Files("C:\Users\me\Completed\"),
#"Filtered Rows" = Table.SelectRows(Source, each ([Extension] = ".xml")),
#"Filtered Hidden Files1" = Table.SelectRows(#"Filtered Rows", each [Attributes]?[Hidden]? <> true),
#"Invoke Custom Function1" = Table.AddColumn(#"Filtered Hidden Files1", "Transform File", each #"Transform File"([Content])),
#"Renamed Columns1" = Table.RenameColumns(#"Invoke Custom Function1", {"Name", "Source.Name"}),
#"Renamed Columns1"
I used used Find & Replace in a text editor and then tweaked to include the variable I needed
Source = Folder.Files(\"" + @[User::MyVariable] + "\"),
#\"Filtered Rows\" = Table.SelectRows(Source, each ([Extension] = \".xml\")),
#\"Filtered Hidden Files1\" = Table.SelectRows(#\"Filtered Rows\", each [Attributes]?[Hidden]? <> true),
#\"Invoke Custom Function1\" = Table.AddColumn(#\"Filtered Hidden Files1\", \"Transform File\", each #\"Transform File\"([Content])),
#\"Renamed Columns1\" = Table.RenameColumns(#\"Invoke Custom Function1\", {\"Name\", \"Source.Name\"}),
