Using a variable as an operator in a Power BI query filter
- Anonymous6 years agoHi vgeldbr
This should work
Table.SelectRows(dbo_VW_PPM_ExportFinancial_FY20, each List.Contains(PortfolioFilterList, [Portfolio]) and fComparerList(SubPortfolioFilterList, [SubPortfolio], if SubPortfolioFilterType then "=" else "<>"))
Kind regards
JB
Hi all,
The M language syntax doesn't support something like Parameter1 Comparer Parameter2, but it perfectly supports Comparer(Parameter1, Parameter2). In this case, the Comparer function can be overloaded at execution time.
This makes possible to do something like this:
#"Portfolio Filter" = "a; b; c",
#"SubPortfolio Filter" = "aa; ab; ba; cb",
#"SubPortfolio Filter Type" = false,
myTable =
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WSlTSUUpMVIrVgTCTU8DMZBAzSSk2FgA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [Portfolio = _t, SubPortfolio = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Portfolio", type text}, {"SubPortfolio", type text}})
in #"Changed Type",
//Variables - Portfolio:
PortfolioFilterList = Text.Split(#"Portfolio Filter", ";"),
//Variables - SubPortfolio:
SubPortfolioFilterList = Text.Split(#"SubPortfolio Filter", ";"),
fComparer = (param1 as any, param2 as any, c_type as text)=>
if c_type = "=" then param1 = param2 else
if c_type = "<" then param1 < param2 else
if c_type = ">" then param1 > param2 else
if c_type = "<=" then param1 <= param2 else
if c_type = ">=" then param1 >= param2 else
if c_type = "<>" then param1 <> param2 else
null,
fComparerList = (param1 as list, param2 as any, c_type as text)=>
if c_type = "=" then List.Contains(param1,param2) else
if c_type = "<>" then not List.Contains(param1,param2) else null,
Source = Table,
#"Filtered Rows" = Table.SelectRows(Source, each List.Contains(PortfolioFilterList, [Portfolio]) and fComparer(SubPortfolioFilterList{0}, [SubPortfolio], "<>")),
#"Filtered Rows Against List" = Table.SelectRows(Source, each List.Contains(PortfolioFilterList, [Portfolio]) and fComparerList(SubPortfolioFilterList, [SubPortfolio], "<>"))
in #"Filtered Rows Against List"
Kind regards,
JB
Thanks Anonymous , this looks very promising. Maybe it's just too late on a Sunday evening but I'm not getting how to integrate this with my code to reference my SQL table. When I use your code there are no syntax errors but when I save I get:
Expression.Error: The import Table matches no exports. Did you miss a module reference?
Sorry, please change Table to myTable in this line:
Source = Table, //Should be Source = myTable,This is the modified code from your example, but I can't test it, let me know if it does not work:
let //Variables - Portfolio: PortfolioFilterList = Text.Split(#"Portfolio Filter", ";"), //Variables - SubPortfolio: SubPortfolioFilterList = Text.Split(#"SubPortfolio Filter", ";"), fComparer = (param1 as any, param2 as any, c_type as text)=> if c_type = "=" then param1 = param2 else if c_type = "<" then param1 < param2 else if c_type = ">" then param1 > param2 else if c_type = "<=" then param1 <= param2 else if c_type = ">=" then param1 >= param2 else if c_type = "<>" then param1 <> param2 else null, fComparerList = (param1 as list, param2 as any, c_type as text)=> if c_type = "=" then List.Contains(param1,param2) else if c_type = "<>" then not List.Contains(param1,param2) else null, Source = Sql.Databases("SQLServerName\INST1"), IT_ITRDB_PRD = Source{[Name="xxxPRD"]}[Data], dbo_VW_PPM_ExportFinancial_FY20 = xxxPRD{[Schema="dbo",Item="VW_PPM_ExportFinancial_FY20"]}[Data], #"Filtered Rows" = Table.SelectRows(dbo_VW_PPM_ExportFinancial_FY20, each List.Contains(PortfolioFilterList, [Portfolio]) and fComparer(SubPortfolioFilterList{0}, [SubPortfolio], "<>")), #"Filtered Rows Against List" = Table.SelectRows(dbo_VW_PPM_ExportFinancial_FY20, each List.Contains(PortfolioFilterList, [Portfolio]) and fComparerList(SubPortfolioFilterList, [SubPortfolio], "<>")) in #"Filtered Rows Against List"By what I can see in your original post you want #"Filtered Rows Against List" as an output (#"Filtered Rows" only checks it against the first item in the SubPortfolioFilterList - I put it as an example if you want to compare it the way in the original post:
each List.Contains(PortfolioFilterList, [Portfolio]) and (fComparer(SubPortfolioFilterList{0}, [SubPortfolio], "<>") and fComparer(SubPortfolioFilterList{1}, [SubPortfolio], "<>") and fComparer(SubPortfolioFilterList{2}, [SubPortfolio], "<>") and fComparer(SubPortfolioFilterList{3}, [SubPortfolio], "<>"))Kind regards,
JB
- vgeldbr6 years ago
Helper IV
This is fantastic. One last piece of logic I'm missing. I have a parameter (SubPortfolio Filter Type) which can be TRUE or FALSE. This allows the user to specify if subportfolio filter includes or excludes the list of SupPortfolios. My code is below now but I can't figure where to set this as your example is assuming always <>.
//Variables - filter type:
SubPortfolioFilterType = if #"SubPortfolio Filter Type" = false then "<>" else "=",
fComparer = (param1 as any, param2 as any, c_type as text) =>
null,
fComparerList = (param1 as list, param2 as any, c_type as text) =>
if c_type = "<>" then not List.Contains(param1,param2) else null,Source = Sql.Databases("DERUSVMPITRSQ01.EY.NET\INST1"),
IT_ITRDB_PRD = Source{[Name="IT_ITRDB_PRD"]}[Data],
dbo_VW_PPM_ExportFinancial_FY20 = IT_ITRDB_PRD{[Schema="dbo",Item="VW_PPM_ExportFinancial_FY20"]}[Data],
#"Filtered Rows Against List" = Table.SelectRows(dbo_VW_PPM_ExportFinancial_FY20, each List.Contains(PortfolioFilterList, [Portfolio]) and fComparerList(SubPortfolioFilterList, [SubPortfolio], "<>"))in #"Filtered Rows Against List"Anonymous- Anonymous6 years agoNot applicableHi vgeldbr
This should work
Kind regards
JB
