Using a variable as an operator in a Power BI query filter
- Anonymous6 years agoHi vgeldbr
This should work
Table.SelectRows(dbo_VW_PPM_ExportFinancial_FY20, each List.Contains(PortfolioFilterList, [Portfolio]) and fComparerList(SubPortfolioFilterList, [SubPortfolio], if SubPortfolioFilterType then "=" else "<>"))
Kind regards
JB
I could be wrong, but I don't think you can replace operators with variables. In other words assigning the = sign to varEqualSign won't let each if [Weight] varEqualSign 10 then 1 else 0 work.
You'd need to multiple IF statements so if it is false, then do and if [blah] <> 1 then something else if [blah] = 1 then something.
If you can use a variable for the operator, I'd love to see the syntax for that.
Hi all,
The M language syntax doesn't support something like Parameter1 Comparer Parameter2, but it perfectly supports Comparer(Parameter1, Parameter2). In this case, the Comparer function can be overloaded at execution time.
This makes possible to do something like this:
let #"Portfolio Filter" = "a; b; c", #"SubPortfolio Filter" = "aa; ab; ba; cb", #"SubPortfolio Filter Type" = false, myTable = let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WSlTSUUpMVIrVgTCTU8DMZBAzSSk2FgA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [Portfolio = _t, SubPortfolio = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Portfolio", type text}, {"SubPortfolio", type text}}) in #"Changed Type", //Variables - Portfolio: PortfolioFilterList = Text.Split(#"Portfolio Filter", ";"), //Variables - SubPortfolio: SubPortfolioFilterList = Text.Split(#"SubPortfolio Filter", ";"), fComparer = (param1 as any, param2 as any, c_type as text)=> if c_type = "=" then param1 = param2 else if c_type = "<" then param1 < param2 else if c_type = ">" then param1 > param2 else if c_type = "<=" then param1 <= param2 else if c_type = ">=" then param1 >= param2 else if c_type = "<>" then param1 <> param2 else null, fComparerList = (param1 as list, param2 as any, c_type as text)=> if c_type = "=" then List.Contains(param1,param2) else if c_type = "<>" then not List.Contains(param1,param2) else null, Source = Table, #"Filtered Rows" = Table.SelectRows(Source, each List.Contains(PortfolioFilterList, [Portfolio]) and fComparer(SubPortfolioFilterList{0}, [SubPortfolio], "<>")), #"Filtered Rows Against List" = Table.SelectRows(Source, each List.Contains(PortfolioFilterList, [Portfolio]) and fComparerList(SubPortfolioFilterList, [SubPortfolio], "<>")) in #"Filtered Rows Against List"Kind regards,
JB
- vgeldbr6 years ago
Helper IV
Thanks Anonymous , this looks very promising. Maybe it's just too late on a Sunday evening but I'm not getting how to integrate this with my code to reference my SQL table. When I use your code there are no syntax errors but when I save I get:
Expression.Error: The import Table matches no exports. Did you miss a module reference?
Sorry, please change Table to myTable in this line:
Source = Table, //Should be Source = myTable,This is the modified code from your example, but I can't test it, let me know if it does not work:
let //Variables - Portfolio: PortfolioFilterList = Text.Split(#"Portfolio Filter", ";"), //Variables - SubPortfolio: SubPortfolioFilterList = Text.Split(#"SubPortfolio Filter", ";"), fComparer = (param1 as any, param2 as any, c_type as text)=> if c_type = "=" then param1 = param2 else if c_type = "<" then param1 < param2 else if c_type = ">" then param1 > param2 else if c_type = "<=" then param1 <= param2 else if c_type = ">=" then param1 >= param2 else if c_type = "<>" then param1 <> param2 else null, fComparerList = (param1 as list, param2 as any, c_type as text)=> if c_type = "=" then List.Contains(param1,param2) else if c_type = "<>" then not List.Contains(param1,param2) else null, Source = Sql.Databases("SQLServerName\INST1"), IT_ITRDB_PRD = Source{[Name="xxxPRD"]}[Data], dbo_VW_PPM_ExportFinancial_FY20 = xxxPRD{[Schema="dbo",Item="VW_PPM_ExportFinancial_FY20"]}[Data], #"Filtered Rows" = Table.SelectRows(dbo_VW_PPM_ExportFinancial_FY20, each List.Contains(PortfolioFilterList, [Portfolio]) and fComparer(SubPortfolioFilterList{0}, [SubPortfolio], "<>")), #"Filtered Rows Against List" = Table.SelectRows(dbo_VW_PPM_ExportFinancial_FY20, each List.Contains(PortfolioFilterList, [Portfolio]) and fComparerList(SubPortfolioFilterList, [SubPortfolio], "<>")) in #"Filtered Rows Against List"By what I can see in your original post you want #"Filtered Rows Against List" as an output (#"Filtered Rows" only checks it against the first item in the SubPortfolioFilterList - I put it as an example if you want to compare it the way in the original post:
each List.Contains(PortfolioFilterList, [Portfolio]) and (fComparer(SubPortfolioFilterList{0}, [SubPortfolio], "<>") and fComparer(SubPortfolioFilterList{1}, [SubPortfolio], "<>") and fComparer(SubPortfolioFilterList{2}, [SubPortfolio], "<>") and fComparer(SubPortfolioFilterList{3}, [SubPortfolio], "<>"))Kind regards,
JB
