im_newbie_123's avatar
im_newbie_123
6 years ago
Use advanced power query editor to use SQL statement
I have a sql statement which is union of two tables.
I want to use the sql statement inside advaced query editor.
My SQL Statement :
SELECT [ABC],[XYZ] FROM TABLE1
UNION
SELECT [PQR],[YAA] FROM TABLE2
I have to create something similar to a view which will have union of these two tables along with a new name for the dataset.
  • v-frfei-msft's avatar
    v-frfei-msft
    Hi im_newbie_123 ,
    In power query, we should rename the column [PQR],[YAA] in table2 to  [ABC],[XYZ], then we can append the tables to get a excepted table.
    Btw, we can enter the sql statement when we connect to the database in power bi desktop.
    As I understand you can not do SQL on PowerQuery but you can do exactly the same operation with an APPEND of two Queries.
    You could write the SQL in PowerQuery:
    = Table.NestedJoin(#"weekly report", {"Unique ID"}, Tracker, {"Unique ID"}, "Tracker", JoinKind.LeftOuter)
