Urgent Help - Power Query - Data Transformation
- 1 year ago
Hi jaineshp
You will need to shape your data so the two headers are parallel in two separate columns. You can do that by accessing the first and second row before promoting the headers and use the combination of the two as the new column names. Unpivot your data after then split the attribute into two separate columns.
let Source = Excel.Workbook(File.Contents("D:\testdata.xlsx"), null, true), Sheet1_Sheet = Source{[Item="Sheet1",Kind="Sheet"]}[Data], #"Automatically Renamed Columns" = let tbl = Sheet1_Sheet, header1 = Record.ToList(Sheet1_Sheet{0}), header2 = Record.ToList(Sheet1_Sheet{1}), zipped = List.Zip({header1, header2}), combined = List.Transform( zipped, //each (if _{0} = null then _{1} else _{0}) & "__" & _{1} //each (if _{0} = null then _{1} & "" else _{0}) & "__" & _{1} each (if _{0} = null then "" else _{0}) & "__" & _{1} ), OriginalColumns = Table.ColumnNames(tbl), renamevalues = List.Zip({OriginalColumns,combined }), renamed = Table.RenameColumns(tbl, renamevalues) in renamed, #"Removed Top Rows" = Table.Skip(#"Automatically Renamed Columns",2), #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Removed Top Rows", {"__Type", "__Qty", "__USD"}, "Attribute", "Value"), #"Renamed Columns" = Table.RenameColumns(#"Unpivoted Other Columns",{{"__Type", "Type"}, {"__Qty", "Qty"}, {"__USD", "USD"}}), #"Split Column by Delimiter" = Table.SplitColumn(#"Renamed Columns", "Attribute", Splitter.SplitTextByDelimiter("__", QuoteStyle.Csv), {"Attribute.1", "Attribute.2"}), #"Renamed Columns1" = Table.RenameColumns(#"Split Column by Delimiter",{{"Attribute.1", "Month"}, {"Attribute.2", "Category"}}), #"Added Custom" = Table.AddColumn(#"Renamed Columns1", "Month Sort", each Date.Month(Date.From([Month] & "1, 2025"))), #"Changed Type" = Table.TransformColumnTypes(#"Added Custom",{{"Value", Int64.Type}, {"Month Sort", Int64.Type}, {"Type", type text}, {"Qty", type text}, {"USD", type text}}) in #"Changed Type"Please see the attached sample pbix.
Hi jaineshp
tbl = Sheet1_Sheet,
zipped,
renamed,
#"Changed Type"
- Lio1231 year ago
Helper II
Hi danextian , Fantastic, thank you so much!
Can you also please provide the explanation along with the excel which has been used in this pbix?
Regards!- danextian1 year ago
This is the excel file I used (moving forward, please post a workable sample data, not an image, not everyone would want to manually type the data). If you pasted the code to AI and asked for an explanation, it would give you quite a decent explanation - probably a lot bettter than i would.
