Urgent Help - Power Query - Data Transformation
- 1 year ago
Hi jaineshp
You will need to shape your data so the two headers are parallel in two separate columns. You can do that by accessing the first and second row before promoting the headers and use the combination of the two as the new column names. Unpivot your data after then split the attribute into two separate columns.
let Source = Excel.Workbook(File.Contents("D:\testdata.xlsx"), null, true), Sheet1_Sheet = Source{[Item="Sheet1",Kind="Sheet"]}[Data], #"Automatically Renamed Columns" = let tbl = Sheet1_Sheet, header1 = Record.ToList(Sheet1_Sheet{0}), header2 = Record.ToList(Sheet1_Sheet{1}), zipped = List.Zip({header1, header2}), combined = List.Transform( zipped, //each (if _{0} = null then _{1} else _{0}) & "__" & _{1} //each (if _{0} = null then _{1} & "" else _{0}) & "__" & _{1} each (if _{0} = null then "" else _{0}) & "__" & _{1} ), OriginalColumns = Table.ColumnNames(tbl), renamevalues = List.Zip({OriginalColumns,combined }), renamed = Table.RenameColumns(tbl, renamevalues) in renamed, #"Removed Top Rows" = Table.Skip(#"Automatically Renamed Columns",2), #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Removed Top Rows", {"__Type", "__Qty", "__USD"}, "Attribute", "Value"), #"Renamed Columns" = Table.RenameColumns(#"Unpivoted Other Columns",{{"__Type", "Type"}, {"__Qty", "Qty"}, {"__USD", "USD"}}), #"Split Column by Delimiter" = Table.SplitColumn(#"Renamed Columns", "Attribute", Splitter.SplitTextByDelimiter("__", QuoteStyle.Csv), {"Attribute.1", "Attribute.2"}), #"Renamed Columns1" = Table.RenameColumns(#"Split Column by Delimiter",{{"Attribute.1", "Month"}, {"Attribute.2", "Category"}}), #"Added Custom" = Table.AddColumn(#"Renamed Columns1", "Month Sort", each Date.Month(Date.From([Month] & "1, 2025"))), #"Changed Type" = Table.TransformColumnTypes(#"Added Custom",{{"Value", Int64.Type}, {"Month Sort", Int64.Type}, {"Type", type text}, {"Qty", type text}, {"USD", type text}}) in #"Changed Type"Please see the attached sample pbix.
Hi jaineshp ,
Appriciate your efforts making me understand.
First header is month (Jan to Dec)
Second header is customer name ( this will change month on month)
First 3 columns would be same for all columns ( row wise)
Also, end result should look something similar to the screenshot I posted previously.
And my data also looks the same way as I wanted the output to be ( same as screenshot)
Please provide me the sample pbix file as I'm new to Power BI, it is quite difficult to follow the steps.
Hi Lio123 ,
Thank you for reaching out to the Microsoft Community Forum.
Please provide sample data that covers your issue or question completely, in a usable format (not as a screenshot). Do not include sensitive information. Do not include anything that is unrelated to the issue or question. Please show the expected outcome based on the sample data you provided.
Dinesh
- v-dineshya1 year ago
Hi Lio123 ,
We haven’t heard from you on the last response and was just checking back to see, Please provide sample data that covers your issue or question completely, in a usable format (not as a screenshot). Do not include sensitive information. Do not include anything that is unrelated to the issue or question. Please show the expected outcome based on the sample data you provided.
Dinesh- Lio1231 year ago
Helper II
Hi v-dineshya ,
Thank you so much for contacting,
There is an excel in the same post, uploaded by SundarRaj . please refer that excel.
Additionally I'm attaching the data screenshot as I won't be able to upload the file from my organization system. Please help me around with this issue, I have been looking for the solution.
This is the data I will have to deal with. Also, please note, values of 2nd double header S, T, X, Y these would change every time, basically this the customer name. It changes every month.
First 3 colums would remain same for other columns
My excel looks like this and I want to show the same thing in Power BI matrix.
Basically input from excel and output from Power BI matrix look the same.
It would really helpful if you could share the sample PBI v-dineshya
Thanks!- Lio1231 year ago
Helper II
Dear v-dineshya,
Can you please help to resolve handle this use case?
Thanks!
