AlexHeinze
2 years agoFrequent Visitor
Switch datasource using IF statement in Power Query
I have a report with 2 datasources. One datasource gets the XML from a file (Source = Xml.Tables(File.Contents(.......): The second datasource gets a similar XML from an API (Source = Xml.Tab...
- 2 years ago
I finally solved it by not referencing the existing sources, instead I put it all in the same place:
let // Get data from API SourceAPI = Xml.Tables(Web.Contents(GatewayURL)), // Get data from file SourceFile = Xml.Tables(File.Contents(SavedScheduleXML)), // Select the sources based on the parameter value Source = if DataSource="API Broadcast" then SourceAPI else SourceFile, .......
WanderingBI
Resolver III
2 years agoWish I could do more than guessing.
When assuming that the issue is only that the column "Table" is of data type any instead of table and this messes with the software receiving the query output (Power BI), would maybe setting the column type to table manually do any good?
Source1 = #"_Get XML from API Broadcast",
Source2 = #"_Get XML from File",
getData = (choice as text) =>
funcsource = if choice = "api" then Source1 else if choice = "file" then Source2 else null
funcsource,
Source = getData ("api"),
SourceAdjustColumnType = Value.ReplaceType(Source, type table [Table = Table.Type])
AlexHeinze
