StuartPQY
1 year agoFrequent Visitor
SQL Script wont run in Power Query
Hello I have some SQL that runs fine in MS SQL Studio, but will not run in Power Apps (in Excel ver 2402 build 16.0.17328.20550) 64 bit) The error I get is DataSource.Error: Microsoft SQL: ...
- Anonymous1 year ago
The fact that the error is coming from the SQL Server means that your steps are correct and the query is getting to the server so the problem is your SQL.
--Nate
PwerQueryKees
1 year agoPlease share your actual (failing) M code with the SQL statement in it. It is probably to do with quoted text inside quoted text.
