MadhavDholakia
2 years agoSplit Values in Power BI Query
Hello, How to split below values in Power BI Query Editor? Sample Values: col 1 1h 40m 56s 23m 45s 34s Expected Results: col 1, col 2, col 3 1, 40, 56 blank, 23, 45 blank, bla...
- 2 years ago
Like this:
Result
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMk5RMDTJUDAyzVUwNCxWitWJVjLMUDAxyFUwNYNwjYxzFUxMIWxjEyAdCwA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t]), Ad_TotalSeconds = Table.AddColumn(Source, "TotalSeconds", each [ a = {{"d", "*86400"}, {"h", "*3600"}, {"m", "*60"}, {"s", "*1"}}, b = List.Accumulate( a, {}, (s,c)=> s & { if not Text.Contains([Column1], c{0}) then null else Text.Replace(List.Select(Text.Split([Column1], " "), (x)=> Text.Contains(x, c{0})){0}?, c{0}, c{1}) } ), c = List.Transform(b, (x)=> try Expression.Evaluate(x) otherwise null), d = List.Sum(c) ][d], Int64.Type), Ad_Splitted = Table.AddColumn(Ad_TotalSeconds, "Splitted", each [ a = Text.SplitAny([Column1], "dhms"), b = List.Transform(List.Select(a, (x)=> Text.Trim(x) <> ""), Number.From), c = List.Repeat({null}, 4 - List.Count(b)) & b, d = Table.FromList({c}, (x)=> x, type table[Days=Int16.Type, Hours=Int64.Type, Minutes=Int64.Type, Seconds=Int64.Type]) ][d], type table), ExpandedSplitted = Table.ExpandTableColumn(Ad_Splitted, "Splitted", {"Days", "Hours", "Minutes", "Seconds"}) in ExpandedSplitted
MadhavDholakia
2 years agothanks dufoq3 - this has worked as expected. There is only one scenario, apologies that was not involved in my initial question, which is not being handled here.
so in case if the value is as given below, i.e., including Day Value - it shows error. Can you please suggest how I can modify your solution to add this as well?
| 2d 7h 34m 58s |
| 1d 5h 4m 10s |
dufoq3
2 years agoLike this:
Result
d = List.Sum(c)
][d], Int64.Type),
][d], type table),
ExpandedSplitted
