MadhavDholakia
2 years agoSplit Values in Power BI Query
Hello, How to split below values in Power BI Query Editor? Sample Values: col 1 1h 40m 56s 23m 45s 34s Expected Results: col 1, col 2, col 3 1, 40, 56 blank, 23, 45 blank, bla...
- 2 years ago
Like this:
Result
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMk5RMDTJUDAyzVUwNCxWitWJVjLMUDAxyFUwNYNwjYxzFUxMIWxjEyAdCwA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t]), Ad_TotalSeconds = Table.AddColumn(Source, "TotalSeconds", each [ a = {{"d", "*86400"}, {"h", "*3600"}, {"m", "*60"}, {"s", "*1"}}, b = List.Accumulate( a, {}, (s,c)=> s & { if not Text.Contains([Column1], c{0}) then null else Text.Replace(List.Select(Text.Split([Column1], " "), (x)=> Text.Contains(x, c{0})){0}?, c{0}, c{1}) } ), c = List.Transform(b, (x)=> try Expression.Evaluate(x) otherwise null), d = List.Sum(c) ][d], Int64.Type), Ad_Splitted = Table.AddColumn(Ad_TotalSeconds, "Splitted", each [ a = Text.SplitAny([Column1], "dhms"), b = List.Transform(List.Select(a, (x)=> Text.Trim(x) <> ""), Number.From), c = List.Repeat({null}, 4 - List.Count(b)) & b, d = Table.FromList({c}, (x)=> x, type table[Days=Int16.Type, Hours=Int64.Type, Minutes=Int64.Type, Seconds=Int64.Type]) ][d], type table), ExpandedSplitted = Table.ExpandTableColumn(Ad_Splitted, "Splitted", {"Days", "Hours", "Minutes", "Seconds"}) in ExpandedSplitted
AlienSx
2 years agolet
Source = sample_table,
tm = Table.TransformColumns(
Source,
{"col 1", (x) =>
Time.ToRecord(
Time.From(
Text.Combine(
List.ReplaceMatchingItems(
Text.ToList(x),
{{" ", "+"}, {"h", "/24"}, {"m", "/1440"}, {"s", "/86400"}}
exp_time = Table.ExpandRecordColumn(tm, "col 1", {"Hour", "Minute", "Second"})
exp_time- MadhavDholakia2 years ago
thanks AlienSx - I am using attachment from an email as a data source so I am not sure how/where I can add the formulas you have shared, can you please help?
let Source = Exchange.Contents("[email protected]"), Mail1 = Source{[Name="Mail"]}[Data], #"Expanded Sender" = Table.ExpandRecordColumn(Mail1, "Sender", {"Name"}, {"Sender.Name"}), #"Filtered Rows" = Table.SelectRows(#"Expanded Sender", each ([Sender.Name] = "Madhav D")), #"Expanded Attachments" = Table.ExpandTableColumn(#"Filtered Rows", "Attachments", {"AttachmentContent"}, {"Attachments.AttachmentContent"}), #"Attachments AttachmentContent" = #"Expanded Attachments"{0}[Attachments.AttachmentContent], #"Imported CSV" = Csv.Document(#"Attachments AttachmentContent",5553,"",ExtraValues.Ignore,65001), #"Changed Type" = Table.TransformColumnTypes(#"Imported CSV",{{"Column1", type text}, {"Column2", type text}, {"Column3", type text}, {"Column4", type text}, {"Column5", type text}, {"Column6", type text}, {"Column7", type text}, {"Column8", type text}, {"Column9", type text}, {"Column10", type text}}), #"Removed Other Columns" = Table.SelectColumns(#"Changed Type",{"Column1"}), #"Split Column by Delimiter" = Table.SplitColumn(#"Removed Other Columns", "Column1", Splitter.SplitTextByDelimiter(",", QuoteStyle.Csv), {"Column1.1", "Column1.2", "Column1.3", "Column1.4", "Column1.5", "Column1.6", "Column1.7", "Column1.8"}), #"Changed Type1" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"Column1.1", type text}, {"Column1.2", type text}, {"Column1.3", type text}, {"Column1.4", type text}, {"Column1.5", type text}, {"Column1.6", type text}, {"Column1.7", type text}, {"Column1.8", type text}}), #"Promoted Headers" = Table.PromoteHeaders(#"Changed Type1", [PromoteAllScalars=true]), #"Changed Type2" = Table.TransformColumnTypes(#"Promoted Headers",{{"ID", type text}, {"Agent Group Name", type text}, {"Created Date", type datetime}, {"Subject", type text}, {"Status", type text}, {"Agent Name", type text}, {"Priority", type text}, {"Overall time spent in business hours", type text}}), #"Duplicated Column" = Table.DuplicateColumn(#"Changed Type2", "Overall time spent in business hours", "Overall time spent in business hours - Copy") in #"Changed Type2"Sample Attachment:
- AlienSx2 years ago
Thanks AlienSx - this fabric community link is broken it seems but I could find the same video on Youtube. It was really helpful.
I have now 3 columns added as Hour, Minute and Second - but all 3 of them are showing error:
Error Details:
Expression.Error: [1,23-1,23] Token Literal expected.
Details:
[List]Expression.Error: [1,18-1,18] Token Literal expected.
Details:
[List]Expression.Error: [1,10-1,10] Token Literal expected.
Details:
[List]This is the current query being used:
let Source = Mail, tm = Table.TransformColumns( Source, {"Overall time spent in business hours", (x) => Time.ToRecord( Time.From( Expression.Evaluate( Text.Combine( List.ReplaceMatchingItems( Text.ToList(x), {{" ", "+"}, {"h", "/24"}, {"m", "/1440"}, {"s", "/86400"}} ) ) ) ) ) } ), exp_time = Table.ExpandRecordColumn(tm, "Overall time spent in business hours", {"Hour", "Minute", "Second"}) in exp_timeCan you please suggest how I can resolve this?
