Split column in Excel's Power Query
- Anonymous2 years ago
Hi SlothCR ,
Please try this way:
Here is the whole M function in the Advanced Editor:let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("rZDLCgIxDEV/JXSlUL/CQRxEGBDcDF3UmpEwaQp9DPj31lm4cFXBVcKBe0/IOKoB4xSit+IQdtDhQnU5W56KuExBKuzFcUm0IOxtwlTJe8Kml4ys4TjommPeamgo62LxnuQBl1DkXsFJgpsrUEZ/X7NqDhTXMhvnj/9KiW7ElJ9/d/5W0KRv/Z8y5gU=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Column1", type text}}), #"Split Column by Delimiter" = Table.SplitColumn(#"Changed Type", "Column1", Splitter.SplitTextByDelimiter("(", QuoteStyle.Csv), {"Column1.1", "Column1.2"}), #"Changed Type1" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"Column1.1", type text}, {"Column1.2", type text}}), #"Split Column by Delimiter1" = Table.SplitColumn(#"Changed Type1", "Column1.2", Splitter.SplitTextByDelimiter(")", QuoteStyle.Csv), {"Column1.2.1", "Column1.2.2"}), #"Changed Type2" = Table.TransformColumnTypes(#"Split Column by Delimiter1",{{"Column1.2.1", type text}, {"Column1.2.2", type text}}), #"Merged Columns" = Table.CombineColumns(#"Changed Type2",{"Column1.1", "Column1.2.2"},Combiner.CombineTextByDelimiter("", QuoteStyle.None),"Merged"), #"Split Column by Delimiter2" = Table.ExpandListColumn(Table.TransformColumns(#"Merged Columns", {{"Merged", Splitter.SplitTextByDelimiter(", ", QuoteStyle.Csv), let itemType = (type nullable text) meta [Serialized.Text = true] in type {itemType}}}), "Merged"), #"Changed Type3" = Table.TransformColumnTypes(#"Split Column by Delimiter2",{{"Merged", type text}}), #"Added Custom" = Table.AddColumn(#"Changed Type3", "Custom", each if Text.Contains([Merged], "Inclusive Case") then "(" & [Column1.2.1] & ")" else ""), #"Inserted Merged Column" = Table.AddColumn(#"Added Custom", "Merged.1", each Text.Combine({[Merged], [Custom]}, ""), type text), #"Removed Columns" = Table.RemoveColumns(#"Inserted Merged Column",{"Column1.2.1", "Merged", "Custom"}) in #"Removed Columns"And the final output is as below:
I'm assuming that the keyword Inclusive Cases is present in all of your lines containing (), so please feel free to modify it to your specific situation:
Dino Tao
If this post helps, then please consider Accept it as the solution to help the other members find it more quickly. - 2 years ago
With this data (added a 4th row with even more splits):
OriginalCol Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Drumming Sound - Knocking Performance - Case Fire - Dark Cases - Visibility, Performance - Device Malfunction - Drumming Sound - Knocking Performance - Device Malfunction - Drumming Sound - Knocking, Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell) Performance - Device Malfunction - Drumming Sound - Knocking, Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Drumming Sound - Knocking I got this result:
OriginalCol col1 col2 col3 col4 Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Drumming Sound - Knocking Performance Device Malfunction Inclusive Cases Case (Intel, HP, Dell) Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Drumming Sound - Knocking Performance Device Malfunction Drumming Sound Knocking Performance - Case Fire - Dark Cases - Visibility, Performance - Device Malfunction - Drumming Sound - Knocking Performance Case Fire Dark Cases Visibility Performance - Case Fire - Dark Cases - Visibility, Performance - Device Malfunction - Drumming Sound - Knocking Performance Device Malfunction Drumming Sound Knocking Performance - Device Malfunction - Drumming Sound - Knocking, Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell) Performance Device Malfunction Drumming Sound Knocking Performance - Device Malfunction - Drumming Sound - Knocking, Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell) Performance Device Malfunction Inclusive Cases Case (Intel, HP, Dell) Performance - Device Malfunction - Drumming Sound - Knocking, Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Drumming Sound - Knocking Performance Device Malfunction Drumming Sound Knocking Performance - Device Malfunction - Drumming Sound - Knocking, Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Drumming Sound - Knocking Performance Device Malfunction Inclusive Cases Case (Intel, HP, Dell) Performance - Device Malfunction - Drumming Sound - Knocking, Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Drumming Sound - Knocking Performance Device Malfunction Inclusive Cases Case (Intel, HP, Dell) Performance - Device Malfunction - Drumming Sound - Knocking, Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Inclusive Cases - Case (Intel, HP, Dell), Performance - Device Malfunction - Drumming Sound - Knocking Performance Device Malfunction Drumming Sound Knocking Here is the M:
let Source = Table.FromRows( Json.Document( Binary.Decompress( Binary.FromText( "i45WCkgtSssvyk3MS05V0FVwSS3LBDJ8E3PSSvOSSzLz84CCnnnJOaXFmWWpCs6JxanFQBEQraDhmVeSmqOj4BGgA9SXk6Opo0CEYS5Fpbm5mXnpCsH5pXkpQAHvvPzkbKCAUqwOumvA1rhlFoENSyzKhtsfllmcmZSZk1lSSXU7STOAKOuJDb/B5Rr6G4YnmmIB", BinaryEncoding.Base64 ), Compression.Deflate ) ), let _t = ( (type nullable text) meta [ Serialized.Text = true ] ) in type table [ OriginalCol = _t ] ), ReplacerChar = "☃", ParseText = Table.AddColumn( Source, "Rows", each let leftSplit = Text.Split([OriginalCol], "("), replaceParenComma = List.Transform( leftSplit, each let rightSplit = Text.Split(_, ")"), replaceComma = if List.Count(rightSplit) > 1 then {Replacer.ReplaceText(rightSplit{0}, ",", ReplacerChar)} & {rightSplit{1}} else rightSplit, comboRightParen = Text.Combine(replaceComma, ")") in comboRightParen ), comboLeftParen = Text.Combine(replaceParenComma, "("), splitRows = List.Transform( Text.Split(comboLeftParen, ","), each Text.Split(Replacer.ReplaceText(_, ReplacerChar, ","), " - ") ) in splitRows, type { { text } } ), ExpandRows = Table.ExpandListColumn(ParseText, "Rows"), ColumnSchema = let MaxFields = List.Max(List.Transform(ExpandRows[Rows], each List.Count(_))), colNames = List.Generate(() => 1, each _ <= MaxFields, each _ + 1, each "col" & Text.From(_)), types = List.Generate( () => 1, each _ <= MaxFields, each _ + 1, each [Optional = false, Type = type nullable text] ) in Record.FromList(types, colNames), ConvertToRecords = let outputType = Type.ForRecord(ColumnSchema, false) in Table.TransformColumns(ExpandRows, {"Rows", each Record.FromList(_, outputType), outputType}), ExpandRecords = Table.ExpandRecordColumn(ConvertToRecords, "Rows", Record.FieldNames(ColumnSchema)) in ExpandRecordsHigh level explanation:
1) Split everything on (
2) Within the resulting list of split text, split again on )
3) Within your double-split text (in a list of a list of text), if there is more than 1 item, the first will be the text in your paren
4) replace your inside-paren-commas with a rare/source-impossible character (specify in ReplacerChar step)
5) combine all your text parts back up - now you are where you started, except your inside-paren-commas are gone and you can split on commas without interference
6) Split on the leftover commas, now you can bring your inside-paren-commas back
Note that the bulk of the work is done in the ParseText step. Expand the rows and then convert your list of split values into columns. Note that everything after ExpandRows is just OCD automation of column expansion, which you can take or leave depending on your scenario.
Hi SlothCR ,
#"Removed Columns"
Dino Tao
