erikboderek
8 years agoRegular Visitor
Split and Extract Not Delimited Column with Multiple Values
I have a spreadsheet where a cell contains multiple values in the format below. vti_parserversion:SR|16.0.0.6105
vti_folderitemcount:IR|0
vti_charset:SR|utf-8
vti_author:SR|i:0i.t|00000003...
- Anonymous8 years ago
erikboderek,
Check this code.let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("hZDBisIwEIZfpXhvSVCL9LSnBQ+CWPRSZYnpxAbaJEwmBaEPb4I9eOju/gNhmMx88zNNsxpJ/ziBHnAE9NqaetA9PLNvDJ5QELRVfZp4WbAYJWfb7GrSjLJ9C6gJBmmDoWp/mtj8JbvEo0VQIJXv5j4RqLO42KYrpgua2FvrPL05U4rnElL2oUk49+XjSnBWG5rZcX9wTlC3iH/09i76a9S4KQbhCTDOnfeXP06wmckPMBCLvxg/aInWW0VZnSwdPyy1dy87GMS/d+Z8XbDV7fYC", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [Column1 = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Column1", type text}}), #"Split Column by Delimiter" = Table.ExpandListColumn(Table.TransformColumns(#"Changed Type", {{"Column1", Splitter.SplitTextByDelimiter("#(lf)", QuoteStyle.Csv), let itemType = (type nullable text) meta [Serialized.Text = true] in type {itemType}}}), "Column1"), #"Changed Type1" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"Column1", type text}}), #"Trimmed Text" = Table.TransformColumns(#"Changed Type1",{{"Column1", Text.Trim, type text}}), #"Cleaned Text" = Table.TransformColumns(#"Trimmed Text",{{"Column1", Text.Clean, type text}}), #"Split Column by Delimiter1" = Table.SplitColumn(#"Cleaned Text", "Column1", Splitter.SplitTextByDelimiter(":", QuoteStyle.Csv), {"Column1.1", "Column1.2"}), #"Pivoted Column" = Table.Pivot(#"Split Column by Delimiter1", List.Distinct(#"Split Column by Delimiter1"[Column1.1]), "Column1.1", "Column1.2") in #"Pivoted Column"
Lydia
erikboderek
Hi Lydia,
Thank you - this works pretty well. The issue I'm running into is that the values in some of the columns are throwing errors.
The error message says "There were too many elements in the enumeration to complete this operation." Based on other posts I've read, is this because there are duplicate values?
I tried pivoting through the UI and selecting "Don't Aggregate" but wound up with the same results.
8 years agoNot applicable
Is there any possibility that you share me the problem data? I will test it in my Desktop.
Lydia
