Thoughtknotseer's avatar
Thoughtknotseer
3 years ago
SelectRows apply to same column cause cyclic reference
Hi
I have a table.
IDExamScore
1
A50
2A60
3A40
4B30
5B20
6B40
Then I hope to add to prepare like below column for using post analysis.
IDExamScoreExamBest
1
A5060
2A6060
3A4060
4B3040
5B2040
6B4040
So I write below expression.
= Table.AddColumn(Filtered, "Custom", List.Max(Table.SelectRows(Scores, (r)=>[Exam]=r[Exam])[Score]))
But this expression cause expression.error a cyclic reference was encountered , How can I avoid?
# Sorry for my poor English, plaese reply me any correction.
  • Hi Thoughtknotseer ,
    You can use the Group by Function in Power Query to achieve your desired result.
    Copy the query below in advanced editor to see steps:
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUXIEYlMDpVidaCUjKNcMwjWGck0gXBMg0wmIjSFcUyjXCMI1g3JBimMB", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ID = _t, Exam = _t, Score = _t]),
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"ID", Int64.Type}, {"Exam", type text}, {"Score", Int64.Type}}),
        #"Grouped Rows" = Table.Group(#"Changed Type", {"Exam"}, {{"MaxScore", each List.Max([Score]), type nullable number}, {"AllRows", each _, type table [ID=nullable number, Exam=nullable text, Score=nullable number]}}),
        #"Expanded AllRows" = Table.ExpandTableColumn(#"Grouped Rows", "AllRows", {"ID", "Score"}, {"ID", "Score"})
        #"Expanded AllRows"
  • m_alireza's avatar
    m_alireza
    Solution Specialist
        #"Expanded AllRows"
    • Dwisha_S's avatar
      Dwisha_S
      Hi, m_alireza ,
      I have similar issue and using Table.Group function and still facing issue.
      I am looking to get the Average of forecast coloumn for Current Week to 6th Week Group by InternalID and I have tried multiple attempts to format the function.
      1)
      let MINDATE = Date.WeekOfYear(DateTime.LocalNow()), Maxdate = MINDATE + 5, Source = #"Demand Fcst Raw Outputs", FilteredTable = Table.Group( Table.SelectRows(Source, each [Week Number] >= MINDATE and [Week Number] <= Maxdate), {"Internal ID"}, {{"TotalForecast", each List.Sum([Forecast]), type number}} ), FinalTable = Table.AddColumn(FilteredTable, "Test", each [TotalForecast] / 6) in FinalTable
      2) let
      FilteredTable = Table.Group(#"Demand Fcst Raw Outputs (2)", [Internal ID],List.Sum[Forecast],[Week Number]=Date.WeekOfYear(DateTime.LocalNow()) and [Week Number]<=Date.WeekOfYear(DateTime.LocalNow())+5),
      FinalTable
  • m_alireza
    Really Thank you!! Table.Group is what I looking for.
    Sorry but can I ask additional question?
    Now I hope to query another column. Example table is below.
    IDExamExamDateScore
    1
    A150
    2A260
    3A340
    4B130
    5B220
    6B340
    I also hope to get below column.
    IDExamExamDateScoreBestScoreBestDate
    1
    A150602
    2A260602
    3A340602
    4B130403
    5B220403
    6B340403
    I was confused I suddenly ordered to use PQ at work. Really thank you for your support.
    • wdx223_Daniel's avatar
      wdx223_Daniel
      NewStep= let GpMx=Table.Buffer(Table.Group(PreviousStepName,"Exam",{"n",each List.MaxN(Table.ToRows([[Score],[ExamDate]]),1,each _{0}){0}})) in #table(Table.ColumnNames(PreviousStepName)&{"BestScore","BestDate"},List.Transform(Table.ToRows(PreviousStepName),each _&GpMx{[Exam=_{1}]}[n]))
