Running Sum with filter slicer problem m - query
using Running Sum in m- query have better performance than dax exp
the only problem is using slicer like dates
we gat the base values of rt
is not Recalculationthen the values after filter
the function
= (val as list ) as list =>
dd=List.Generate(
()=>[ xx =0 , zz=val{0} ],
each [xx] <=List.Count(val) ,
each [ xx=[xx]+1 , zz = [zz] + val{ [xx]+1 } ] , each [zz]
) in dd
and then
Table.FromColumns(
{ aaa[n] ,aaa [val] , fxRunTotal(aaa[val]) }
- mahoneypat
Not totally clear on your scenario, but columns created either with the query editor or with a DAX expressions will not respond slicers. They calculated only when the data model is refreshed. You need to write measures to get filtering by slicers.
Pat
- project101Frequent Visitor
tanks for your answer
very simple
microsoft in quick measure runningsum sample is very very slow for amount of records
Because for every row is recalculate from start to current row
better approach is to run index like idx=idx+1 like while loopim m query you can use it in List.Generate by passing list column paramter from you table
the problem i in filtering data
the rt start from the base value unlike dax exp
{1,2,3,4,5} list for filtering the number 5 the rt exp will be 10 instead 5
this is the value that we need in m - query before the exp dax
- mahoneypat
There may be a more optimized way to write your DAX measure, so you may want to share that. For the M solution, can you provide a small sample table that shows your desired output.
Pat
- AnonymousNot applicable
Hi project101 ,
Better to provide a data sample and expected output.
Refer to:
How to provide sample data in the Power BI Forum
Eyelyn Qin
