ChandanGauns's avatar
ChandanGauns
2 years ago
Running SQL Stored Procedure from Power BI Query
I am using DirectQuery Data Mode to fetch data from SQL Server for my Power BI Report. I followed the below steps:
Above configuration generated the following query:
When I open the Query, I can see the preview of that SP's output.
But when I click on Close and Apply, its giving me the following error:
How do I fix this?
  • amustafa's avatar
    amustafa
    Icon for Solution Sage rankSolution Sage
    Can you please paste your full M Code from Power Query? Here's a general code with correct syntax.
    Source = Sql.Database(ServerName, DatabaseName),
    Query = "EXEC YourStoredProcedure @Parameter1 = Value1, @Parameter2 = Value2",
    Result = Source{[Schema="dbo",Item="YourStoredProcedure"]}[Data]
    Result
  • hi amustafa
    Below is my query:
        Source = Sql.Database("1.2.3.4,1234", "MyDB", [Query="EXEC [dbo].[MyStoredProc] '2023'"])
        Source
    I tried using your solution but its not working as expected.
    • amustafa's avatar
      amustafa
      I was able to run the following query in Direct Query mode instead of Import Query and load the data form Power Query just fine. I have also made it a paramaterized query.
      CustomerID = customeridparam,
      Source = Sql.Database("localhost", "AdventureWorks",
      [Query="EXEC GetCustomerOrderSummary customer_id = " & Text.From(CustomerID)])
      Source
