Refresh problem on Power Pivot
- 4 years ago
Hi ssaintlouis
According to the error message, the connection may be broken. You can go to Data > Existing Connections to verify the connections in the current workbook. If a connection is not configured correctly, you can right click on the connection and click "Edit Connection Properties..." to configure it.
Community Support Team _ Jing
Hi ssaintlouis
Thx man, it solved my problem
