JayZee70's avatar
JayZee70
1 year ago
Problems with PYTD values
Hello I am having some issues with my code for PYTD sales. The one that I am using is working fine BUT there is an issue when some sales are NOT coming in every day. Then my tables won't show anyt...
  • Cookistador's avatar
    1 year ago
     Why are you not using SAMEPERIODLASTYEAR ?
    And your measure becomes something like:
    PYTD Sales KG/L =
    CALCULATE(
    'Total Sales'[Sales KG/L],
    SAMEPERIODLASTYEAR('Calendar'[Date])
    If it is not what you are trying to achieve, can you share a small sample of your data and the expected result?
  • v-achippa's avatar
    1 year ago
    Hi JayZee70,
    The issue occurs because DATEADD requires continuous date values, and missing sales days can cause the calculation to break.
    Use the below measure so that all days are included even when sales data is missing:
    PYTD Sales KG/L = VAR _MaxDate = MAX('Calendar'[Date]) --> To get the latest available date
    RETURN CALCULATE(SUM('Total Sales'[Sales KG/L]),
        DATESBETWEEN('Calendar'[Date],
            _MaxDate - 364,  -- Start date: 364 days ago
            _MaxDate         -- End date: Latest available date
    If this post helps, then please consider Accepting as solution to help the other members find it more quickly, don't forget to give a "Kudos" – I’d truly appreciate it!
    Thanks and regards,
    Anjan Kumar Chippa
