SimonSchoutz's avatar
SimonSchoutz
1 year ago
Problem with grouping/counting values
Hello everyone,
i receive data of weighting process, the data i receive are as following:
ComponentBatchWeight
A120,2
B131
C143
D152,1
E160,9
E161
D152,2
C143,1
B131
A120,2
I want to add a column to count "weight procedure", like this, so when all components of the mixture added to the weighting process, it should increase the value:
ComponentBatchWeightWeight procedure
A120,21
B1311
C1431
D152,11
E160,91
E1612
D152,22
C143,12
B1312
A120,22
Now there is a problem. Sometimes, it could happen, when one batch of a component is not sufficient for required amount, there are used 2 batches for example like this:
A120,2
B131
C143
D151
D15-21,1
E160,9
E161
D152,2
C143,1
B131
A120,2
As you can see, there are in total 2 issues:
1) My data are alternating beginning to count from component A -> component E and then from component E -> component A before it repeats.
2) Sometimes there are not only 5 batches in one mix but 6 or 7, so i can´t simply count to 5 until i add +1 to "Weight procedure" number.
Is there a clever way to add a column to count the number of weight procedure, when all components are added?
Looking forward to your ideas.
Kind regards,
Simon
  • Here is a sample code you can start from...
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("ZVBJEsAgCPsLZ2UqLu212ysc//+NijpW8cKQIAkxRjhBgaFcNiRIKsLFhOVS4M2dy8UW+DD0fVqh5n2DlXq5D0XQD4SuHm6k7GDb18zsQ23+39F8xJ1Ljko02+WNFxoo0hLuIu+UpmgESYgVPGZNI3+Y2nfMd6UP", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Component = _t, Batch = _t, Weight = _t]),
        set_types = Table.TransformColumnTypes(Source,{{"Component", type text}, {"Batch", type text}, {"Weight", type number}}),
        add_zero_index = Table.AddIndexColumn(set_types, "Index", 0, 1, Int64.Type),
        add_isSequenced = Table.AddColumn(add_zero_index, "isSequenced", each try if Number.Abs(Number.From(add_zero_index[Batch]{[Index]+1}) - Number.From([Batch])) = 1 then "yes" else "no" otherwise null, type text),
        add_local_group_values = Table.AddColumn(add_isSequenced, "Local Group Values", each if ([Component] = "A" or [Component] = "E") and [isSequenced] = "yes" then [Component] else null, type text),
        fill_down = Table.FillDown(add_local_group_values,{"Local Group Values"}),
        remove_columns = Table.RemoveColumns(fill_down,{"Index", "isSequenced"}),
        local_grouping = Table.Group(remove_columns, {"Local Group Values"}, {{"All Rows", each _, type table [Component=nullable text, Batch=nullable text, Weight=nullable number, #"Local Group Values"=text]}}, GroupKind.Local),
        add_weight_procedure = Table.AddIndexColumn(local_grouping, "Weight Procedure", 1, 1, Int64.Type),
        expand_columns = Table.ExpandTableColumn(add_weight_procedure, "All Rows", {"Batch", "Component", "Weight"}, {"Batch", "Component", "Weight"}),
        remove_local_group = Table.RemoveColumns(expand_columns,{"Local Group Values"}),
        reorder_columns = Table.ReorderColumns(remove_local_group,{"Component", "Batch", "Weight", "Weight Procedure"})
        reorder_columns
    Starting with this data...
    It transforms into...
    • SimonSchoutz's avatar
      SimonSchoutz
      Result should look like this:
      A120,21
      B1311
      C1431
      D1511
      D15-21,11
      E160,91
      E1612
      D152,22
      C143,12
      B1312
      A120,22
        reorder_columns
      SimonSchoutz
      Wow, thank you for your quick support. I think i got an issue with the sequence section.
      Batch could also contain letters and not only numbers for example:
      A
      D2309357
      5
      B
      DE7G009639
      2,3
      C
      DG24B7162B
      1,1
      D
      DG24G7017A
      4
      E
      ADN0214100
      16
      E
      ADN0214100
      15
      D
      DG24H7048A
      3,5
      C
      DG24B7162B
      1,0
      B
      DE7G009639
      2,5
      A
      D2309357
      4,5
      I think, this breaks the seqeuence method listed above, right?
      One thing, which might help in building a sequence, component E has always the biggest weight number. So maybe it makes sense to add up the weight numbers until i reach a certain threshhold, in this case (5+2,3+1,1+4+16 = ) 28,4, so if value is e.g. >25, next measurement should be next weight procedure, right?
      • jgeddes's avatar
        jgeddes
        It does break the sequence.
        What would the Batch number look like there were two or more batches in a single sequence? In your first example they were differentiated with '-2' etc. Would that hold true with your new example data?
  • dufoq3's avatar
    dufoq3
    Hi SimonSchoutz, what about this?
    Output
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("dY87EsMwCETvQk3BT8Iq7cgjV7mAxve/RoScJplRB/uWBXqHHRCqKBVNPsoEN3Y4Qjy9EZWsZTSCOsErQBM7nLOEi5EnqF/QnNgj06Z8jmqvbxI2Jgp/XujpJ+Zysi1iFNNqMa1OfSb+HrOQ7w8=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Component = _t, Batch = _t, Weight = _t]),
        ChangedType = Table.TransformColumnTypes(Source,{{"Weight", type number}}, "en-US"),
        CompDistinct = List.Buffer(List.Distinct(ChangedType[Component])),
        Comp = List.Buffer(ChangedType[Component]),
        GenWeightProcedure = List.Generate(
            ()=> [ x = 0, y = {Comp{x}}, z = false, w = false, q = 1 ],
            each [x] < List.Count(Comp),
            each [ x = [x]+1,
                   y = if z then {Comp{x}} else [y] & {Comp{x}},
                   z = List.ContainsAll([y] & {Comp{x}} , CompDistinct),
                   w = if z then true else false,
                   q = if [w] then [q]+1 else [q] ],
            each [q] ),
        Merged = Table.FromColumns(Table.ToColumns(ChangedType) & {GenWeightProcedure}, Value.Type(Table.FirstN(ChangedType, 0) & #table(type table[Weight Procedure=Int64.Type], {})))
        Merged
    Hi SimonSchoutz ,
    Hi SimonSchoutz,
