Anonymous's avatar
7 years ago
Problem using an if statement with a column name with a "/" in it
I have a line like this in my query:
= Table.ReplaceValue(#"Replaced Value11", each [CBT], each if [Customer Name/Customer ID]= "Sample Name" then "Something" else [CBT],Replacer.ReplaceValue,{"CBT"} )
and it generates an error in the if statement pointing to the text prior to the / saying Expression.SyntaxError: Invalid identifier.
However, if I change the column reference in the if statement to a column name without a / in it, it works fine.  Can someone explain why it doesn't like the / in the column name?  Will a / in the column name cause problems in other areas?
thanks,
  • AnkitBI's avatar
    AnkitBI
    7 years ago
    Just a Syntax thing to handle special characters in Column Name. Ideally we shall avoid special characters in Name if not necessary.
  • AnkitBI's avatar
    AnkitBI
    Icon for Solution Sage rankSolution Sage
    Try below using #"Customer Name/Customer ID".
    = Table.ReplaceValue(#"Changed Type", each [CBT], each if [#"Customer Name/Customer ID"]= "Sample Name" then "Something" else [CBT],Replacer.ReplaceValue,{"CBT"} )
    Ankit Jain
    Do Mark it as solution if the response resolved your problem. Do like the response if it seems good and helpful.
      Thanks AnkitBI  for the tip.  Do you know why the behavior in the if statement is different for column names with a / and those without?  Should I avoid using / in my column names?
      thanks,
      Chad
      • AnkitBI's avatar
        AnkitBI
