Problem connection Power BI to MySQL data source
- 7 years ago
Hi Peterfrb2 ,
Before we can connect to a MySQL database, we need to install MySQL Connector/Net 6.6.5 for Microsoft Windows on our computer. Select the driver that matches your Power BI Desktop installation (32-bit or 64-bit).
After installing the MySQL connector, refer to this blog to connect to MySQL in Power BI Desktop.
If the connection still fails in Power BI Desktop, please check that if you are able to connect to the MySQL database in MySQL workbench, ensure that MySQL workbench is installed in the same machine as Power BI Desktop.(Note: Please understand that this link is provided above with no warranties or guarantees of content changes, and confers no rights.)
Cherry
Thanks to you my problem is resolved now.
hello,
i have installed connector and still getting the same error.
i dont see connections option in SQL server community and i reconfigure sql workbench still getting the same error,
Please guide how can i resolve the issue.
Thank you
