papi0506
4 years agoFrequent Visitor
Power query using variables in script blocks for POST API calls
Still new to power bi and it truly is a powerful tool. I'm running into one road block with my power query. The only way I've been able to make a proper POST API call to retreive data is by putting t...
- 4 years ago
Hi papi0506
Try concatenating the string pieces rather than having everything in one string. Place the following M code in a blank query to see an example
let #"tryagain" = "GetInThere", BodyContent_= "{ ""password"" : " & #"tryagain" & " }" in BodyContent_Please accept the solution when done and consider giving a thumbs up if posts are helpful.
Vijay_A_Verma
Most Valuable Professional
4 years agoCan you paste the query as text in this post so that experts can work on your query?
papi0506
I'll keep that in mind for next time. AIB's suggestion worked perfectly and I can even use it with parameters now {yeaaaa}. Thank you very much tho.
