papi0506
4 years agoFrequent Visitor
Power query using variables in script blocks for POST API calls
Still new to power bi and it truly is a powerful tool. I'm running into one road block with my power query. The only way I've been able to make a proper POST API call to retreive data is by putting t...
- 4 years ago
Hi papi0506
Try concatenating the string pieces rather than having everything in one string. Place the following M code in a blank query to see an example
let #"tryagain" = "GetInThere", BodyContent_= "{ ""password"" : " & #"tryagain" & " }" in BodyContent_Please accept the solution when done and consider giving a thumbs up if posts are helpful.
Vijay_A_Verma
Most Valuable Professional
4 years agoCan you paste the query as text in this post so that experts can work on your query?
- papi05064 years agoFrequent Visitor
I'll keep that in mind for next time. AIB's suggestion worked perfectly and I can even use it with parameters now {yeaaaa}. Thank you very much tho.
