Klik's avatar
Klik
11 months ago
Power Query Underlying Problem
Can anyone assist? 😔 I've been migrating to Power BI Service and have been stuck on this issue for two weeks. Everything looks fine in preview, no yellow warnings but, when I load it into the repo...
  • v-saisrao-msft's avatar
    11 months ago
    Hi Klik,
    Please try the updated M-Query Below
        Source = SharePoint.Contents("https://miscbhd.sharepoint.com/sites/xxxx", [ApiVersion = 15]),
        Library = Source{[Name="Shared Documents"]}[Content],
        FilteredFiles = Table.SelectRows(Library, each Text.Contains([Name], "ENGINEERING") and Text.EndsWith([Name], ".xlsx")),
        SortedFiles = Table.Sort(FilteredFiles, {{"Date modified", Order.Descending}}),
        LatestFile = Table.FirstN(SortedFiles, 1),
        Binary = LatestFile{0}[Content],
        ExcelContent = Excel.Workbook(Binary, false),
        PossibleNames = {"Dashboard", "DASHBOARD"},
        FilteredSheet = Table.SelectRows(ExcelContent, each List.Contains(PossibleNames, [Name])),
        Extracted = if Table.IsEmpty(FilteredSheet) then #table({}, {}) else FilteredSheet{0}[Data],
        #"Removed Top Rows" = Table.Skip(Extracted, 4),
        #"Removed Other Columns" = Table.SelectColumns(#"Removed Top Rows", {
            "Column1", "Column2", "Column3", "Column4", "Column5",
            "Column6", "Column7", "Column8", "Column9", "Column10",
            "Column11", "Column12", "Column13", "Column14"
        #"Promoted Headers" = Table.PromoteHeaders(#"Removed Other Columns", [PromoteAllScalars = true]),
        #"Removed Top Rows1" = Table.Skip(#"Promoted Headers", 1),
        #"Removed Bottom Rows" = Table.RemoveLastN(#"Removed Top Rows1", 2),
        #"Renamed Columns" = Table.RenameColumns(#"Removed Bottom Rows", {
            {"%#(lf)PLAN ", "PLAN"},
            {"%#(lf)ACTUAL ", "ACTUAL"},
            {"%#(lf)VAR. ", "VAR"},
            {"%#(lf)BAL.", "BAL"},
            {"TOTAL", "TOTAL"}
        }, MissingField.Ignore),
        #"Changed Type" = Table.TransformColumnTypes(#"Renamed Columns", {
            {"TOTAL", Int64.Type},
            {"PLAN", Percentage.Type},
            {"ACTUAL", Percentage.Type},
            {"VAR", Percentage.Type},
            {"BAL", Percentage.Type}
        #"Changed Type"
