Klik
1 year agoFrequent Visitor
Power Query Underlying Problem
Can anyone assist? đ I've been migrating to Power BI Service and have been stuck on this issue for two weeks. Everything looks fine in preview, no yellow warnings but, when I load it into the repo...
- 1 year ago
Hi Klik,
Please try the updated M-Query Below
let Source = SharePoint.Contents("https://miscbhd.sharepoint.com/sites/xxxx", [ApiVersion = 15]), Library = Source{[Name="Shared Documents"]}[Content], FilteredFiles = Table.SelectRows(Library, each Text.Contains([Name], "ENGINEERING") and Text.EndsWith([Name], ".xlsx")), SortedFiles = Table.Sort(FilteredFiles, {{"Date modified", Order.Descending}}), LatestFile = Table.FirstN(SortedFiles, 1), Binary = LatestFile{0}[Content], ExcelContent = Excel.Workbook(Binary, false), PossibleNames = {"Dashboard", "DASHBOARD"}, FilteredSheet = Table.SelectRows(ExcelContent, each List.Contains(PossibleNames, [Name])), Extracted = if Table.IsEmpty(FilteredSheet) then #table({}, {}) else FilteredSheet{0}[Data], #"Removed Top Rows" = Table.Skip(Extracted, 4), #"Removed Other Columns" = Table.SelectColumns(#"Removed Top Rows", { "Column1", "Column2", "Column3", "Column4", "Column5", "Column6", "Column7", "Column8", "Column9", "Column10", "Column11", "Column12", "Column13", "Column14" }), #"Promoted Headers" = Table.PromoteHeaders(#"Removed Other Columns", [PromoteAllScalars = true]), #"Removed Top Rows1" = Table.Skip(#"Promoted Headers", 1), #"Removed Bottom Rows" = Table.RemoveLastN(#"Removed Top Rows1", 2), #"Renamed Columns" = Table.RenameColumns(#"Removed Bottom Rows", { {"%#(lf)PLAN ", "PLAN"}, {"%#(lf)ACTUAL ", "ACTUAL"}, {"%#(lf)VAR. ", "VAR"}, {"%#(lf)BAL.", "BAL"}, {"TOTAL", "TOTAL"} }, MissingField.Ignore), #"Changed Type" = Table.TransformColumnTypes(#"Renamed Columns", { {"TOTAL", Int64.Type}, {"PLAN", Percentage.Type}, {"ACTUAL", Percentage.Type}, {"VAR", Percentage.Type}, {"BAL", Percentage.Type} }) in #"Changed Type"Thank you.
Omid_Motamedise
1 year agoyou can make your error handling more robust
or
Extracted =
#table(type table [], {})
else
try FilteredSheet{0}[Data] otherwise #table(type table [], {})
This ensures that if the workbook changes or is missing the âDashboardâ sheet, it returns a blank table instead of crashing.
Klik
Still the same error popping Sir đ
- v-saisrao-msft1 year ago
Hi Klik,
