2 years agoNot applicable
Power Query to reference cells
In new column, I am trying to replicate following excel formula within Power Query, but unable to do it.
=IF(A10<>"",B10,C9)
The formula is "If A10 is not blank, then select value within B10, otherwise select the above cell value of C column"
Any help on this will be great.
1 Reply
- AlienSx
Hi, Anonymous at least 4 options come into my mind:
# the one when you add a copy of C to your table but shift it 1 row down
let Source = your_table, C_shift = List.Buffer({null} & List.RemoveLastN(Source[C], 1)), tbl = Table.FromColumns(Table.ToColumns(Source) & {C_shift}, Table.ColumnNames(Source) & {"C_shift"}), add_C = Table.AddColumn(tbl, "D", each if [A] <> null then [B] else [C_shift]), remove_shift = Table.RemoveColumns(add_C, "C_shift") in remove_shift# the one with index column and C a list
let Source = your_table, C = List.Buffer({null} & Source[C]), idx = Table.AddIndexColumn(Source, "idx", 1, 1), add_d = Table.AddColumn(idx, "D", each if [A] <> null then [B] else C{[idx] - 1}?), remove = Table.RemoveColumns(add_d, "idx") in remove# the one with index column and C as record with field names = index
let Source = your_table, C = Record.FromList(Source[C], List.Transform({1..Table.RowCount(Source)}, Text.From)), idx = Table.AddIndexColumn(Source, "idx", 0, 1), add_d = Table.AddColumn(idx, "D", each if [A] <> null then [B] else Record.FieldOrDefault(C, Text.From([idx]))), remove = Table.RemoveColumns(add_d, "idx") in remove# and finally the fastest one - using List.Generate
let Source = your_table, r = List.Buffer(Table.ToRecords(Source)), g = List.Generate( () => [i = 0, row = r{0}, res = row & [D = if row[A] <> null then row[B] else null]], (x) => r{x[i]}? <> null, (x) => [i = x[i] + 1, row = r{i}, res = row & [D = if row[A] <> null then row[B] else x[row][C]]], (x) => x[res] ), z = Table.FromRecords(g) in z
