TuqueLogic
1 year agoPower Query Recursion: Simple reference of same row
Just looking to do a simple recursive reference but Power Query doesn't seem to be simple with recursion. Table with 3 columns: Index, Date, AdjustedDate Date is a datetime var, imported da...
- 1 year ago
Maybe this is what you are looking for. Just a note, though, that recursions usually perform very badly in Power Query and there is usually a way more performant, non-recursive method to get the same results. This is partly why lots of people are giving you non-recursive solutions.
SourceData:
Index Date 0 5/1/2025 1 5/12/2025 2 4/1/2025 3 4/1/2025 4 4/1/2025 5 5/23/2025 6 5/19/2025 7 6/1/2025 8 5/28/2025 let Source = SourceData, AddPreviousHigher = let srcBuf = Table.Buffer( Source ) in Table.AddColumn( srcBuf, "PreviousHigherDate", each let recF = ( x as number ) => let thisDate = srcBuf{x}[Date] in if x = 0 then thisDate else let prevDate = srcBuf{x-1}[Date] in if thisDate > prevDate then thisDate else @recF( x - 1) //recursion in recF([Index]), type date ) in AddPreviousHigherOutput:
Edit: realized I got the recursive logic wrong, tweaked to reflect OP's clarificaiton
v-saisrao-msft
1 year agoHi TuqueLogic,
I wanted to check if you had the opportunity to review the information provided. Please feel free to contact us if you have any further questions. If any of the response has addressed your query, please accept it as a solution and give a 'Kudos' so other members can easily find it.
