Power Query Recursion: Simple reference of same row
- 1 year ago
Maybe this is what you are looking for. Just a note, though, that recursions usually perform very badly in Power Query and there is usually a way more performant, non-recursive method to get the same results. This is partly why lots of people are giving you non-recursive solutions.
SourceData:
Index Date 0 5/1/2025 1 5/12/2025 2 4/1/2025 3 4/1/2025 4 4/1/2025 5 5/23/2025 6 5/19/2025 7 6/1/2025 8 5/28/2025 let Source = SourceData, AddPreviousHigher = let srcBuf = Table.Buffer( Source ) in Table.AddColumn( srcBuf, "PreviousHigherDate", each let recF = ( x as number ) => let thisDate = srcBuf{x}[Date] in if x = 0 then thisDate else let prevDate = srcBuf{x-1}[Date] in if thisDate > prevDate then thisDate else @recF( x - 1) //recursion in recF([Index]), type date ) in AddPreviousHigherOutput:
Edit: realized I got the recursive logic wrong, tweaked to reflect OP's clarificaiton
Hi TuqueLogic, check this:
version with index (slower)
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlDSUTIyMDLVNzAEIqVYnWglQ2QhI7CQEZKQoQFYyBhZlQVYyARZlTFYyBRNKBYA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Index = _t, Date = _t]),
ChangedType = Table.TransformColumnTypes(Source,{{"Index", Int64.Type}, {"Date", type date}}),
Ad_AdjustedDate = Table.AddColumn(ChangedType, "Adjusted Date", each let a = try ChangedType{[Index]-1} otherwise [Date=[Date]] in if [Date] > a[Date] then [Date] else a[Date], type date)
Ad_AdjustedDate
much faster version (index column is not needed)
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMjIwMtU3MAQipVgdJK4RCtfQAFXWAlXWGIMbCwA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Date = _t]),
ChangedType = Table.TransformColumnTypes(Source,{{"Date", type date}}),
Ad_PevDate = Table.FromColumns(Table.ToColumns(ChangedType) & {{null} & List.RemoveLastN(ChangedType[Date], 1)}, Value.Type(Table.FirstN(ChangedType, 0) & #table(type table[PrevDate=date], {}))),
Ad_AdjustedDate = Table.AddColumn(Ad_PevDate, "Adjusted Date", each if [Date] > ([PrevDate] ?? [Date]) then [Date] else ([PrevDate] ?? [Date]), type date),
RemovedColumns = Table.RemoveColumns(Ad_AdjustedDate,{"PrevDate"})
RemovedColumnsThanks for the reply.
I don't see how this is recursive. But that may just be me.
The date to use is not necessarily only 1 row previous relative to the index.
The date to use may be many rows previous.
As well the column index is needed as the original dates are not necessarily relevant to the operation.
If it was only a shift of 1 or 2 I was concerned with I would just created index shifted merged columns and evaluate at a row level with DAX.
And here all I did was replace the hashtable that determines the initial input and it doesn't work in this cae.
I don't understand why not, but this is the result.
