Power Query Recursion: Simple reference of same row
- 1 year ago
Maybe this is what you are looking for. Just a note, though, that recursions usually perform very badly in Power Query and there is usually a way more performant, non-recursive method to get the same results. This is partly why lots of people are giving you non-recursive solutions.
SourceData:
Index Date 0 5/1/2025 1 5/12/2025 2 4/1/2025 3 4/1/2025 4 4/1/2025 5 5/23/2025 6 5/19/2025 7 6/1/2025 8 5/28/2025 let Source = SourceData, AddPreviousHigher = let srcBuf = Table.Buffer( Source ) in Table.AddColumn( srcBuf, "PreviousHigherDate", each let recF = ( x as number ) => let thisDate = srcBuf{x}[Date] in if x = 0 then thisDate else let prevDate = srcBuf{x-1}[Date] in if thisDate > prevDate then thisDate else @recF( x - 1) //recursion in recF([Index]), type date ) in AddPreviousHigherOutput:
Edit: realized I got the recursive logic wrong, tweaked to reflect OP's clarificaiton
PQ definitely support recursive functions. Your example does not contain any function though, so I do not understand your question.
FYI a recursive function: (the sign before the call of the function #"!" tells PQ it is a recursive call)
Did I answer your question? Then please (also) mark my post as a solution and make it easier to find for others having a similar problem.
Remember: You can mark multiple answers as a solution...
If I helped you, please click on the Thumbs Up to give Kudos.
Kees Stolker
A big fan of Power Query and Excel
