jo123456
2 years agoPower Query Help
I posted the message here but it got deleted. I need some help with Power Query. I have data per row value that has installed packages information with line breaks. I need to create new rows per line...
- Anonymous2 years ago
Hi jo123456
You can try the following code.
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("nZJNawMhEIb/iuRcB1bzferSQwmkdKEttGSDGNfsSl2V1aVJf33Nps0nveT1ojLPzDuji0VvbnkhC+R0Wyrjp0huQsM9Q74tS+mDssbfodxobkrHxWc8uEbZRgUl/V3rCh4krm0ocjMzPnCtY7IsBvJI5yb98mkpTYDNeMiGfdSJQFwTSiDBJKFx092qPzw3j9LOMng/IAQGu1gCvP42FBKgF0C2/Uif5mdFEAVyzZxCXOhzooMoDAgm/T2Grhmniss6SewGTw6FyCHbCei2obIGr+JknG2Cx95rVvMgKlZZHwyvJRjLG1HlBt0guhsREHxi+6hrH2K9Pu+CwDCOePD/tMqmXVHsRHzsotXS/7rt2GkkKE5gPNqRIPUIhLytj6Pus9eUPcS/8/yCR+yt+2meYba33VsufwA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [installed_packages = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"installed_packages", type text}}), #"Split Column by Delimiter" = Table.TransformColumns(#"Changed Type", {{"installed_packages", each Text.AfterDelimiter(_, "Installed Packages")}}), Custom1 = Table.TransformColumns(#"Split Column by Delimiter", {{"installed_packages", Splitter.SplitTextByAnyDelimiter({"#(lf)", " "})}}), Custom2 = Table.TransformColumns(Custom1, {{"installed_packages", each Table.FromRows(List.Split(List.RemoveItems(_, {""}),3),{"package","version","status"})}}), #"Expanded installed_packages" = Table.ExpandTableColumn(Custom2, "installed_packages", {"package", "version", "status"}, {"package", "version", "status"}), #"Merged Columns" = Table.CombineColumns(#"Expanded installed_packages",{"package", "version", "status"},Combiner.CombineTextByDelimiter(" ", QuoteStyle.None),"Merged") in #"Merged Columns"It can improve the performent.
Best Regards!
Yolo Zhu
jo123456
2 years agoAnonymous, it's taking a long time to load but would you have any guidance in translating this code to sql so it's not so intensive on Power BI. Uisng Postgresql
2 years agoNot applicable
Hi jo123456
#"Merged Columns"
Best Regards!
Yolo Zhu
- jo1234562 years ago
thank you so much
