jo123456
2 years agoPower Query Help
I posted the message here but it got deleted. I need some help with Power Query. I have data per row value that has installed packages information with line breaks. I need to create new rows per line...
- Anonymous2 years ago
Hi jo123456
You can try the following code.
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("nZJNawMhEIb/iuRcB1bzferSQwmkdKEttGSDGNfsSl2V1aVJf33Nps0nveT1ojLPzDuji0VvbnkhC+R0Wyrjp0huQsM9Q74tS+mDssbfodxobkrHxWc8uEbZRgUl/V3rCh4krm0ocjMzPnCtY7IsBvJI5yb98mkpTYDNeMiGfdSJQFwTSiDBJKFx092qPzw3j9LOMng/IAQGu1gCvP42FBKgF0C2/Uif5mdFEAVyzZxCXOhzooMoDAgm/T2Grhmniss6SewGTw6FyCHbCei2obIGr+JknG2Cx95rVvMgKlZZHwyvJRjLG1HlBt0guhsREHxi+6hrH2K9Pu+CwDCOePD/tMqmXVHsRHzsotXS/7rt2GkkKE5gPNqRIPUIhLytj6Pus9eUPcS/8/yCR+yt+2meYba33VsufwA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [installed_packages = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"installed_packages", type text}}), #"Split Column by Delimiter" = Table.TransformColumns(#"Changed Type", {{"installed_packages", each Text.AfterDelimiter(_, "Installed Packages")}}), Custom1 = Table.TransformColumns(#"Split Column by Delimiter", {{"installed_packages", Splitter.SplitTextByAnyDelimiter({"#(lf)", " "})}}), Custom2 = Table.TransformColumns(Custom1, {{"installed_packages", each Table.FromRows(List.Split(List.RemoveItems(_, {""}),3),{"package","version","status"})}}), #"Expanded installed_packages" = Table.ExpandTableColumn(Custom2, "installed_packages", {"package", "version", "status"}, {"package", "version", "status"}), #"Merged Columns" = Table.CombineColumns(#"Expanded installed_packages",{"package", "version", "status"},Combiner.CombineTextByDelimiter(" ", QuoteStyle.None),"Merged") in #"Merged Columns"It can improve the performent.
Best Regards!
Yolo Zhu
jo123456
2 years agothis seems like it worked but the data is taking a long time to load. I will accept it the solution though
jo123456
2 years agoAnonymous, it's taking a long time to load but would you have any guidance in translating this code to sql so it's not so intensive on Power BI. Uisng Postgresql
Hi jo123456
Best Regards!
Yolo Zhu
- jo1234562 years ago
thank you so much
