Power Query Help
- Anonymous2 years ago
Hi jo123456
You can try the following code.
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("nZJNawMhEIb/iuRcB1bzferSQwmkdKEttGSDGNfsSl2V1aVJf33Nps0nveT1ojLPzDuji0VvbnkhC+R0Wyrjp0huQsM9Q74tS+mDssbfodxobkrHxWc8uEbZRgUl/V3rCh4krm0ocjMzPnCtY7IsBvJI5yb98mkpTYDNeMiGfdSJQFwTSiDBJKFx092qPzw3j9LOMng/IAQGu1gCvP42FBKgF0C2/Uif5mdFEAVyzZxCXOhzooMoDAgm/T2Grhmniss6SewGTw6FyCHbCei2obIGr+JknG2Cx95rVvMgKlZZHwyvJRjLG1HlBt0guhsREHxi+6hrH2K9Pu+CwDCOePD/tMqmXVHsRHzsotXS/7rt2GkkKE5gPNqRIPUIhLytj6Pus9eUPcS/8/yCR+yt+2meYba33VsufwA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [installed_packages = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"installed_packages", type text}}), #"Split Column by Delimiter" = Table.TransformColumns(#"Changed Type", {{"installed_packages", each Text.AfterDelimiter(_, "Installed Packages")}}), Custom1 = Table.TransformColumns(#"Split Column by Delimiter", {{"installed_packages", Splitter.SplitTextByAnyDelimiter({"#(lf)", " "})}}), Custom2 = Table.TransformColumns(Custom1, {{"installed_packages", each Table.FromRows(List.Split(List.RemoveItems(_, {""}),3),{"package","version","status"})}}), #"Expanded installed_packages" = Table.ExpandTableColumn(Custom2, "installed_packages", {"package", "version", "status"}, {"package", "version", "status"}), #"Merged Columns" = Table.CombineColumns(#"Expanded installed_packages",{"package", "version", "status"},Combiner.CombineTextByDelimiter(" ", QuoteStyle.None),"Merged") in #"Merged Columns"It can improve the performent.
Best Regards!
Yolo Zhu
Hi
lbendlin ,Thanks for your concern about the problem, and i want to offer some more information for user to refer to.
hello jo123456 , you can create a blank query and put the following code to advanced editor in power query.
#"Split Column by Delimiter" = Table.ExpandListColumn(Table.TransformColumns(#"Changed Type", {{"installed_packages", Splitter.SplitTextByDelimiter("#(lf)", QuoteStyle.Csv), let itemType = (type nullable text) meta [Serialized.Text = true] in type {itemType}}}), "installed_packages"),
#"Changed Type1" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"installed_packages", type text}}),
#"Added Index" = Table.AddIndexColumn(#"Changed Type1", "Index", 1, 1, Int64.Type),
#"Added Custom" = Table.AddColumn(#"Added Index", "Custom", each let
a =List.Max(Table.SelectRows(#"Added Index",(x)=>x[Index]=[Index]+1)[installed_packages]),
b=if Text.StartsWith(a," ") then [installed_packages]&" "&Text.TrimStart(a) else [installed_packages]
in try b otherwise null),
#"Filtered Rows" = Table.SelectRows(#"Added Custom", each (not Text.StartsWith([installed_packages], " ")) and Text.Select([installed_packages],{"0".."9"})<>""),
#"Removed Columns" = Table.RemoveColumns(#"Filtered Rows",{"installed_packages", "Index"})
#"Removed Columns"
Output
Best Regards!
Yolo Zhu
- jo1234562 years ago
this seems like it worked but the data is taking a long time to load. I will accept it the solution though
Anonymous, it's taking a long time to load but would you have any guidance in translating this code to sql so it's not so intensive on Power BI. Uisng Postgresql
Hi jo123456
Best Regards!
Yolo Zhu
