Power Query Help
I posted the message here but it got deleted. I need some help with Power Query. I have data per row value that has installed packages information with line breaks. I need to create new rows per line break but I'm running to issues where some packages and their repos are broken off to different lines. I just need help solution.
this is how it looks per row
and this is how I want it to look
desired output
let me know if you need a sample table
- Anonymous2 years ago
Hi jo123456
You can try the following code.
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("nZJNawMhEIb/iuRcB1bzferSQwmkdKEttGSDGNfsSl2V1aVJf33Nps0nveT1ojLPzDuji0VvbnkhC+R0Wyrjp0huQsM9Q74tS+mDssbfodxobkrHxWc8uEbZRgUl/V3rCh4krm0ocjMzPnCtY7IsBvJI5yb98mkpTYDNeMiGfdSJQFwTSiDBJKFx092qPzw3j9LOMng/IAQGu1gCvP42FBKgF0C2/Uif5mdFEAVyzZxCXOhzooMoDAgm/T2Grhmniss6SewGTw6FyCHbCei2obIGr+JknG2Cx95rVvMgKlZZHwyvJRjLG1HlBt0guhsREHxi+6hrH2K9Pu+CwDCOePD/tMqmXVHsRHzsotXS/7rt2GkkKE5gPNqRIPUIhLytj6Pus9eUPcS/8/yCR+yt+2meYba33VsufwA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [installed_packages = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"installed_packages", type text}}), #"Split Column by Delimiter" = Table.TransformColumns(#"Changed Type", {{"installed_packages", each Text.AfterDelimiter(_, "Installed Packages")}}), Custom1 = Table.TransformColumns(#"Split Column by Delimiter", {{"installed_packages", Splitter.SplitTextByAnyDelimiter({"#(lf)", " "})}}), Custom2 = Table.TransformColumns(Custom1, {{"installed_packages", each Table.FromRows(List.Split(List.RemoveItems(_, {""}),3),{"package","version","status"})}}), #"Expanded installed_packages" = Table.ExpandTableColumn(Custom2, "installed_packages", {"package", "version", "status"}, {"package", "version", "status"}), #"Merged Columns" = Table.CombineColumns(#"Expanded installed_packages",{"package", "version", "status"},Combiner.CombineTextByDelimiter(" ", QuoteStyle.None),"Merged") in #"Merged Columns"It can improve the performent.
Best Regards!
Yolo Zhu
- lbendlin
Please provide sample data that covers your issue or question completely, in a usable format (not as a screenshot).
Do not include sensitive information or anything not related to the issue or question.
If you are unsure how to upload data please refer to https://community.fabric.microsoft.com/t5/Community-Blog/How-to-provide-sample-data-in-the-Power-BI-Forum/ba-p/963216
Want faster answers? https://community.fabric.microsoft.com/t5/Desktop/How-to-Get-Your-Question-Answered-Quickly/m-p/1447523- jo123456
- AnonymousNot applicable
Hi
lbendlin ,Thanks for your concern about the problem, and i want to offer some more information for user to refer to.hello jo123456 , you can create a blank query and put the following code to advanced editor in power query.
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("nZJNawMhEIb/iuRcB1bzferSQwmkdKEttGSDGNfsSl2V1aVJf33Nps0nveT1ojLPzDuji0VvbnkhC+R0Wyrjp0huQsM9Q74tS+mDssbfodxobkrHxWc8uEbZRgUl/V3rCh4krm0ocjMzPnCtY7IsBvJI5yb98mkpTYDNeMiGfdSJQFwTSiDBJKFx092qPzw3j9LOMng/IAQGu1gCvP42FBKgF0C2/Uif5mdFEAVyzZxCXOhzooMoDAgm/T2Grhmniss6SewGTw6FyCHbCei2obIGr+JknG2Cx95rVvMgKlZZHwyvJRjLG1HlBt0guhsREHxi+6hrH2K9Pu+CwDCOePD/tMqmXVHsRHzsotXS/7rt2GkkKE5gPNqRIPUIhLytj6Pus9eUPcS/8/yCR+yt+2meYba33VsufwA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [installed_packages = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"installed_packages", type text}}), #"Split Column by Delimiter" = Table.ExpandListColumn(Table.TransformColumns(#"Changed Type", {{"installed_packages", Splitter.SplitTextByDelimiter("#(lf)", QuoteStyle.Csv), let itemType = (type nullable text) meta [Serialized.Text = true] in type {itemType}}}), "installed_packages"), #"Changed Type1" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"installed_packages", type text}}), #"Added Index" = Table.AddIndexColumn(#"Changed Type1", "Index", 1, 1, Int64.Type), #"Added Custom" = Table.AddColumn(#"Added Index", "Custom", each let a =List.Max(Table.SelectRows(#"Added Index",(x)=>x[Index]=[Index]+1)[installed_packages]), b=if Text.StartsWith(a," ") then [installed_packages]&" "&Text.TrimStart(a) else [installed_packages] in try b otherwise null), #"Filtered Rows" = Table.SelectRows(#"Added Custom", each (not Text.StartsWith([installed_packages], " ")) and Text.Select([installed_packages],{"0".."9"})<>""), #"Removed Columns" = Table.RemoveColumns(#"Filtered Rows",{"installed_packages", "Index"}) in #"Removed Columns"Output
Best Regards!
Yolo Zhu
