DiKi-I
Post Partisan
2 years agoPower query help
Hi , I have multiple relationship table around 5 to 6 which are available in mutiple tables. I'm attaching some sample data there are 3 tables table1, table2, table3. Realtionship is from parent...
DiKi-I
Post Partisan
2 years agoHi,
I tested the above and now I am getting the result quickly but if the values are same I am getting null in the child only getting the value in the first parent.
values are below in my data
business service= A
business service line =A
department = A
and I final result I am getting from you m query is:
business service= A
business service line =null
department = null
my data is like this
spinfuzer
Solution Sage
2 years agomerging by parent and parentclassname instead of just parent.
Table1 = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUUoqLc7MSy0uVihOLSrLTE4FCrlgEVbIAXKVYnWilZywa3LFq8kZuyY3cjS5k6MpAq8mRxwhgVUcqi0WAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Parent = _t, Parentclassname = _t, Child = _t, Childclassname = _t]),
Table2 = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclHSUUoqLc7MSy0uVihOLSrLTE5VyAFygeIeQJySWpBYVJKbmleiFKsTreSKR7knpnI3PMq9MJW741HuTZpyH0zlEXiUR4HcHwJW5uiIRx1YEtncWAA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Parent = _t, Parentclassname = _t, Child = _t, Childclassname = _t]),
Table3 = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45W8lDSUUpJLUgsKslNzSsBcnyB2DNEKVYnWskTXc4PIeeFLuePkPNGlwvAIxeIkPNBlwuCysUCAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Parent = _t, Parentclassname = _t, Child = _t, Childclassname = _t]),
Combined = Table.Buffer(Table.Combine({Table1,Table2,Table3})),
tree = (tbl as table, optional n as number) =>
update_tree =
if List.Contains(Table.ColumnNames(tbl),"tree")
then
// Change to Parent Columns
Table.ReplaceValue(tbl, each [tree], each Record.AddField([tree], [Parentclassname], [Parent]), Replacer.ReplaceValue,{"tree"})
else
Table.AddColumn(tbl,"tree", each Record.AddField([], [Parentclassname], [Parent])), // Change to Parent Column
removeOldParent = Table.RemoveColumns(update_tree, {"Parent", "Parentclassname"}), // Change to Parent Column
renameChildToParent = Table.RenameColumns(removeOldParent, {{"Child","Parent"},{"Childclassname","Parentclassname"}}),
getNextChild = if List.NonNullCount(renameChildToParent[Parent]) <> 0 and n < 10 // remove and n < 10 after checking for loops
then
@tree(
Table.ExpandTableColumn(
Table.NestedJoin(
renameChildToParent,{"Parent","Parentclassname"}, // Change to Parent Column
Combined,{"Parent","Parentclassname"}, // Change to Parent Column
"nextChild",
JoinKind.LeftOuter
"nextChild",
{"Child","Childclassname"} // Change to Child Column
, n+1 // remove this check
else Table.SelectColumns(renameChildToParent,"tree")
getNextChild,
final = tree(Table1,0), // remove the ,0 after fixing query and fixing infinite loops
#"Expanded tree" = Table.ExpandRecordColumn(final, "tree", {"business service", "business service line", "department", "IT"}, {"business service", "business service line", "department", "IT"})
#"Expanded tree"
