Power query help
I tried with only two tables initially but its not loading and taking forever.
There is no circular dependency (A->B)
There are around 2k records
Are you sure you are referring to the right columns in the join and not inadvertantly going from A --> A --> A--> A in an infinite loop instead of A --> B?
I added 500 random records and it ran just fine. Do you have a larger data sample?
- DiKi-I2 years ago
Post Partisan
Hi
I checked the data the classname is different but in some cases the parent and child will be same.
For those entries I am getting many rows.
Hierarachy can be same for some records.- spinfuzer2 years ago
Solution Sage
Are you saying you have something like
Parent = AA, Parent Class Name = Business Service
Child = BB, Parent Class Name = Business Service
What is your expected result there?
Solution Sage
see latest reply
- DiKi-I2 years ago
Post Partisan
I tested the above and now I am getting the result quickly but if the values are same I am getting null in the child only getting the value in the first parent.
values are below in my data
business service= Abusiness service line =A
department = A
and I final result I am getting from you m query is:business service= A
business service line =null
department = null
my data is like this
