Power query help
hi DiKi-I ,
I would:
1. Merge "parent" in Table 3 with "child" table 2. Expand table 3 ( Child and Child Class name)
2. Merge "parent" in Table 2 with "child" in table 1. Expand table 2 ( Child, Childclassname, Table3.Child, Table3.ChildClassname) Which is shown below:
Now you could remove the parent&childclass name columns and rename other columns to get :
Note: This is currently not dynamic and is not ideal if there is more than one department.
However, If this meets your requirements, I will explore making it more dynamic.
Let me know.
I am pasting the steps from the advanced editor for the tables below:
table1
Source = Excel.Workbook(File.Contents("C:\Users\Avi\Downloads\Data1.xlsx"), null, true),
Table1_Sheet = Source{[Item="Table1",Kind="Sheet"]}[Data],
#"Promoted Headers" = Table.PromoteHeaders(Table1_Sheet, [PromoteAllScalars=true]),
#"Changed Type" = Table.TransformColumnTypes(#"Promoted Headers",{{"Parent", type text}, {"Parentclassname", type text}, {"Child ", type text}, {"Childclassname", type text}}),
#"Filtered Rows" = Table.SelectRows(#"Changed Type", each ([Parent] <> null)),
#"Merged Queries" = Table.NestedJoin(#"Filtered Rows", {"Child "}, #"Table 2", {"Parent"}, "Table 2", JoinKind.LeftOuter),
#"Expanded Table 2" = Table.ExpandTableColumn(#"Merged Queries", "Table 2", {"Child ", "Childclassname", "Table 3.Child ", "Table 3.Childclassname"}, {"Table 2.Child ", "Table 2.Childclassname", "Table 2.Table 3.Child ", "Table 2.Table 3.Childclassname"}),
#"Removed Columns" = Table.RemoveColumns(#"Expanded Table 2",{"Parentclassname", "Childclassname", "Table 2.Childclassname", "Table 2.Table 3.Childclassname"}),
#"Renamed Columns" = Table.RenameColumns(#"Removed Columns",{{"Table 2.Table 3.Child ", "IT"}, {"Table 2.Child ", "Department"}, {"Parent", "Business service"}, {"Child ", "Business Service Line"}})
#"Renamed Columns"
table2:
Table1_Sheet = Source{[Item="Table2",Kind="Sheet"]}[Data],
#"Merged Queries" = Table.NestedJoin(#"Filtered Rows", {"Child "}, #"Table 3", {"Parent"}, "Table 3", JoinKind.LeftOuter),
#"Expanded Table 3" = Table.ExpandTableColumn(#"Merged Queries", "Table 3", {"Child ", "Childclassname"}, {"Table 3.Child ", "Table 3.Childclassname"})
#"Expanded Table 3"
table3:
Table1_Sheet = Source{[Item="Table3",Kind="Sheet"]}[Data],
#"Filtered Rows"
Thanks for solution. I also have to handle one scenario where one table has mutiple child class. In that case I have to check the parent of the previous parent doesn't exist then only the child class will be used. I have updated the sheet.
normally the hierarchy is business service->business service line -> department -> IT but
in some cases it may be business service->business service line --> IT. That's why multiple child class exist in the table 2 .
eg
like Z is mapped directly to IT instead of department. So if the department is not mapped then map to child else if department exist then ignore the child 'IT' in this case.
let me if this explains the scenario.
