Power Query help
Does anyone know how i can convert this using power query or from excel.
The header is on the 1st column, it organize in a weekly fashion.
The spreadsheet was not designed by me. But i need import the data into PBI.
Good, so you add the category-field to the unpivot others step:
// Table1 let Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content], #"Filtered Rows2" = Table.SelectRows(Source, each ([Column1] <> null)), #"Added Custom" = Table.AddColumn(#"Filtered Rows2", "Week", each if Text.StartsWith([Column1], "Week ") then [Column1] else null), #"Filled Down" = Table.FillDown(#"Added Custom",{"Week"}), #"Promoted Headers" = Table.PromoteHeaders(#"Filled Down", [PromoteAllScalars=true]), #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Promoted Headers", {"Week 1", "Week 1_1", "category"}, "Attribute", "Value"), #"Renamed Columns" = Table.RenameColumns(#"Unpivoted Other Columns",{{"Attribute", "Date"}}), #"Filtered Rows" = Table.SelectRows(#"Renamed Columns", each not Text.StartsWith([Week 1], "Week ")), #"Filtered Rows1" = Table.SelectRows(#"Filtered Rows", each ([Value] <> "")), #"Renamed Columns1" = Table.RenameColumns(#"Filtered Rows1",{{"Week 1", "Row"}, {"Week 1_1", "Week"}}), #"Changed Type1" = Table.TransformColumnTypes(#"Renamed Columns1",{{"Value", type number}, {"category", type text}}) in #"Changed Type1"
- ImkeFCommunity Champion
// Table1 let Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content], #"Filtered Rows2" = Table.SelectRows(Source, each ([Column1] <> null)), #"Added Custom" = Table.AddColumn(#"Filtered Rows2", "Week", each if Text.StartsWith([Column1], "Week ") then [Column1] else null), #"Filled Down" = Table.FillDown(#"Added Custom",{"Week"}), #"Promoted Headers" = Table.PromoteHeaders(#"Filled Down", [PromoteAllScalars=true]), #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Promoted Headers", {"Week 1", "Week 1_1", "category"}, "Attribute", "Value"), #"Renamed Columns" = Table.RenameColumns(#"Unpivoted Other Columns",{{"Attribute", "Date"}}), #"Filtered Rows" = Table.SelectRows(#"Renamed Columns", each not Text.StartsWith([Week 1], "Week ")), #"Filtered Rows1" = Table.SelectRows(#"Filtered Rows", each ([Value] <> "")), #"Renamed Columns1" = Table.RenameColumns(#"Filtered Rows1",{{"Week 1", "Row"}, {"Week 1_1", "Week"}}), #"Changed Type1" = Table.TransformColumnTypes(#"Renamed Columns1",{{"Value", type number}, {"category", type text}}) in #"Changed Type1" - ImkeFCommunity Champion
Hi VincenzoChean ,
will there always only be 7 columns with dates or could there be more or less? (This is relevant for how to determine the columns that shall be unpivoted.)
With regards to the m-code, in this video I show how to use code from the internet and paste it into the advanced editor: Dynamically solve parent child hierarchies in Power BI and Power Query - YouTube- VincenzoCheanHelper I
Hi
Yes it will be. Thanks a lot.
Hi VincenzoChean ,
please paste the following code into the advanced editor and follow the steps:let Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content], #"Filtered Rows2" = Table.SelectRows(Source, each ([Column1] <> null)), #"Added Custom" = Table.AddColumn(#"Filtered Rows2", "Week", each if Text.StartsWith([Column1], "Week ") then [Column1] else null), #"Filled Down" = Table.FillDown(#"Added Custom",{"Week"}), #"Promoted Headers" = Table.PromoteHeaders(#"Filled Down", [PromoteAllScalars=true]), #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Promoted Headers", {"Week 1", "Week 1_1"}, "Attribute", "Value"), #"Renamed Columns" = Table.RenameColumns(#"Unpivoted Other Columns",{{"Attribute", "Date"}}), #"Filtered Rows" = Table.SelectRows(#"Renamed Columns", each not Text.StartsWith([Week 1], "Week ")), #"Filtered Rows1" = Table.SelectRows(#"Filtered Rows", each ([Value] <> "")), #"Renamed Columns1" = Table.RenameColumns(#"Filtered Rows1",{{"Week 1", "Row"}, {"Week 1_1", "Week"}}), #"Changed Type1" = Table.TransformColumnTypes(#"Renamed Columns1",{{"Value", type number}}) in #"Changed Type1"File also attached.
Hi
Thanks for assisting. i forgot there's another column that has to go onto it.
Can you please assist again ?
Secondly, do i have to add to 'Data model' before i can use the power query editor ?
I tried going into advance editor but there's no data to select.
- KT_Bsmart2getheImpactful Individual
Hi VincenzoChean ,
Below transformation code should be dynamic enough to turn the data into structured data formate:
//Get Source
Source = Excel.CurrentWorkbook(){[Name="Table2"]}[Content],//Unpivot other column other than the first one (i.e. week1,2, column)
#"Unpivoted Other Columns" = Table.UnpivotOtherColumns(Source, {"Column1"}, "Attribute", "Value"),
//Add conditional column to get "Week", then fill down
#"Added Custom1" = Table.AddColumn(#"Unpivoted Other Columns", "Custom", each if Text.StartsWith([Column1],"Week") then [Column1] else null),
#"Filled Down" = Table.FillDown(#"Added Custom1",{"Custom"}),//Filter for only the header rows
ColumnTbl = Table.SelectRows(#"Filled Down", each Text.StartsWith([Column1],"Week")),
//Filter for all row except header rows
NonColumnTbl = Table.SelectRows(#"Filled Down", each not Text.StartsWith([Column1],"Week")),
//Join the main table (the content without header) with header table to get table
#"Merged Queries" = Table.NestedJoin(NonColumnTbl, {"Custom", "Attribute"}, ColumnTbl, {"Custom", "Attribute"}, "NonColumnTbl", JoinKind.LeftOuter),
#"Expanded NonColumnTbl" = Table.ExpandTableColumn(#"Merged Queries", "NonColumnTbl", {"Value"}, {"Date"}),//Rename header (rename to whatever name you want)
#"Renamed Columns" = Table.RenameColumns(#"Expanded NonColumnTbl",{{"Column1", "Measure / Title"}, {"Custom", "Week Number"}}),
//Remove access columns
#"Removed Columns1" = Table.RemoveColumns(#"Renamed Columns",{"Attribute"})
#"Removed Columns1"Regards
KT
Hi VincenzoChean ,
I just realised that you have attached the source file.
See below link for the solution.
Regards
KT
- wdx223_DanielCommunity Champion
= Table.Combine(Table.Group(Source,"Column1",{"n",each let a=Table.PromoteHeaders(Table.SelectRows(_,each [Column1]<>null)),b=Table.UnpivotOtherColumns(a,List.RemoveRange(Table.ColumnNames(a),1,7),"Date","x") in Table.RenameColumns(Table.Pivot(b,List.Distinct(Table.ToColumns(b){0}),Table.ColumnNames(b){0},"x"),{{"dates","category"}},1)},0,(x,y)=>Byte.From(Text.StartsWith(y??"","Week ")))[n])
