cool_333
3 years agoFrequent Visitor
Power Query help replace date with zero or null
Hi all, I was wondering if you gurus can help. I'm trying to replace all the different dates that appear in the value column with either 0 or null whichever works in the power query. Thank you in...
latimeria
Solution Specialist
3 years agoHi cool_333 ,
Try this, using Table.TransformColumns:
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("VZBLDsUgDAPvwjpS8wGSd5aK+1+jTwWp9tIzFii+76Z+aV6uHk1aVVvyZwHMquTgjniUxMYDsOvpTuxmytw46eUuvnFRO6Rv/AOcdv4zxfIXXmfojB1eCuF1dHGwo7M7u0GTsKMJJjva4QtrPQ==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Date = _t, ValueIni = _t]),
#"Added Custom" = Table.AddColumn(Source, "Value", each try Number.FromText([ValueIni]) otherwise Date.FromText([ValueIni])),
#"Removed Columns" = Table.RemoveColumns(#"Added Custom",{"ValueIni"}),
#"Changed Type" = Table.TransformColumnTypes(#"Removed Columns",{{"Date", type date}}),
#"===Start here" = #"Changed Type",
#"Replaced Date" = Table.TransformColumns(
#"===Start here",
{"Value", each if Value.Is(_, Date.Type) then null else _ }
#"Replaced Date"
