Power Query Conditional Running Total with If Statement - Advanced Problem
- 4 years ago
Hi SpreadsheetPete,
This is probably not the neatiest solution, but you can try something like this:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTLQMzACU4amQMpQKVYHLm6KEDdCFjdHiBvjUG+CLG6JEDcFizth2GuGLI5kjjmyOJK9FmBxZwxxSyRxEyRzDA2QNSA5yBDo41gA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Filter = _t, Volume = _t, Cube = _t, Index = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Filter", type text}, {"Volume", type number}, {"Cube", type number}, {"Index", type text}}), Aggregate = List.Accumulate(Table.ToRecords(#"Changed Type"), {}, (a,n)=> a & { Record.AddField(Record.AddField(n, "CubeFill", n[Volume] + (if List.IsEmpty(a) or List.Last(a)[CubeFill] + n[Volume] > n[Cube] or List.Last(a)[Filter] <> n[Filter] then 0 else List.Last(a)[CubeFill])), "PositionCount", if List.IsEmpty(a) or List.Last(a)[Filter] <> n[Filter] then 1 else if List.Last(a)[CubeFill] + n[Volume] > n[Cube] then List.Last(a)[PositionCount]+Number.RoundUp(n[Volume]/n[Cube], 0) else List.Last(a)[PositionCount])}), Output = Table.FromRecords(Aggregate) in OutputKind regards,
John
- 4 years ago
I corrected the code in fxCalc.
(A)=> let RunningTotal = Table.AddColumn( A, "Running Total", each if [Volume] < (Number.RoundUp(List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) / [Cube], 0) * [Cube]) - List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) then @RunningTotal[Running Total]{[Index]-1} + [Volume] else List.Sum(List.FirstN(A[Volume],[Index]+1)) + ((Number.RoundUp(List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0})) / [Cube], 0) * [Cube]) - List.Sum(List.InsertRange(List.FirstN(A[Volume],[Index]),0,{0}))) ), CubeFill = Table.AddColumn( RunningTotal, "Cube Fill", each [Running Total]/[Cube] ), PositionCount = Table.AddColumn( CubeFill, "Position Count", each Number.RoundUp([Cube Fill],0) ), RemainingSpace = Table.AddColumn( PositionCount, "Remaining Space", each [Position Count] * [Cube] - [Running Total] ) in RemainingSpaceMain Query:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclTSUTLQMzACU4amSrE6cDFTLGLmRKqzRBZzwmKHExa9TljscMYpZmKKRR3C3lgA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Filter = _t, Volume = _t, Cube = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Filter", type text}, {"Volume", type number}, {"Cube", type number}}), #"Grouped Rows" = Table.Group(#"Changed Type", {"Filter"}, {{"Group", each fxCalc(Table.AddIndexColumn(_,"Index",0,1))}}), Combine = Table.Combine(#"Grouped Rows"[Group]) in CombineRegards
KT
Amazing Thank you
I did have some luck by adopting the below code and it works very closely yet it causes missed calculations after only some of the records. here is my latest code.
Also here is the updated Excel file demonstrating the output of the code and the error
the best code so far
Source = Excel.CurrentWorkbook(){[Name="SourceTable"]}[Content],
#"Added Index" = Table.AddIndexColumn(Source, "Index", 0, 1,
Int64.Type),
CorrectTypes = Table.TransformColumnTypes(#"Added Index",{{"Index",
Int64.Type}, {"Filter", type text}, {"Volume", type number}}),
each List.Sum(Table.SelectRows(CorrectTypes, (Q) => Q[Filter] =
[Filter] and Q[Index] <= [Index])[Volume]), type number),
Runing = Table.Group(CorrectTypes,"Filter",{"A", each let
A = Table.AddIndexColumn(_,"i")
in Table.AddColumn(A,"R", each
List.Accumulate(Table.SelectRows(A, (a)=> a[i]<=[i])[Volume],
[Running=0, Verifier = 1],
// Here the challenge begins
(s,l)=> [Running = if s[Running]+l >
(Number.RoundUp(s[Running]+[Volume]/[Cube])*[Cube]) then
((Number.RoundUp(s[Running]/[Cube])*[Cube])-s[Running])+s[Running]+
[Volume] else s[Running]+l , Verifier =Number.From(s[Running]+l
<=Number.RoundUp(s[Running]/[Cube])*[Cube] )] ))
ExpandedR = Table.ExpandRecordColumn(
Table.ExpandTableColumn(Runing, "A", {"Volume","Cube","i", "R"}),
"R", {"Running", "Verifier"})
and here is the output
Code Output and formulas with desired outcome
Hi SpreadsheetPete ,
Please see below code (There are still a slight variance in the calculation which I will look into it tomorrow.)
Working query:
Combine
fxCalc:
(A)=>
A,
"Running Total",
each
if [Volume] <
then List.Sum(List.FirstN(A[Volume],[Index]+1))
RunningTotal,
"Cube Fill",
CubeFill,
"Position Count",
PositionCount,
"Remaining Space",
RemainingSpace
Regards
KT
- KT_Bsmart2gethe4 years ago
Impactful Individual
KT
- SpreadsheetPete4 years agoRegular Visitor
KT
THANK YOU VERY MUCH!!!
You Are The Winner Here as your code does exactly what I was struggling with for over a week now.
This is absolutely amazing! I cannot thank you enough
Beautiful work!
John,
Thank you to you too as your code is also very good and very useful and it has provided me a different perspective To my challenge so also very grateful for your work.
You are both lifesavers!
Kind Regards
Pete
